Question about Dometic RM2852 Refrigerator
Fridge went to gas when power went out. when power came back on fridge didn't swith back to power. worked until gas went out. is there a problem with a switch somewhere or does the unit need replacing
  • 905 Answers
Many RVs / Coaches have the fridge power receptacle protected by a GFCI outlet that is located in the kitchen, perhaps bathroom, areas. Check to see if this outlet is tripped. If it isn't, try plugging a lamp into the fridge outlet to see if it works.
If it does, then the control board may have gotten spiked by a converter surge while power was being lost (also a sign of a failing converter). You can also measure the resistance of the heating element with a multimeter. You should see about 44 ohms (give or take 10%). If the heating element is out of tolerance, the fridge won't use it, but it should throw a code indicating a problem.
If the outlet doesn't work, look for other dead outlets in your coach. Double check GFCI outlets, make sure they are not tripped. And, of course, make sure that all your breakers are turned on, and not partially tripped as well.
Posted on Jul 18, 2010
Fridge does not work on gas or elec Fuse is good have power
If the back of the refrigerator is getting warm and the refrigerator is level then you more then likely will require a replacement cooling unit. You can visit our online Store or give us a call directly 1-888-782-6665 We ship throughout North America!
Sep 13, 2014 | Dometic CS-200 Wine Cooler
Have a 2 year old SAMSUNG RS2545SH Side by Side
This is going to be a problem with either the thermostat control or the compressor relay from the freezer to frigde, either way, you will need to call a service tech.
Jul 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Computer
Well you've lost power to one or two major circuits. Could be a problem with the key switch or a major fuse in the engine compartment.
I would check the fuses for power and find out which ones are dead then go from there.
Jul 23, 2013 | 2000 Chevrolet Malibu
Why does the check engine light comes on saying the gas cap is loose or off when it is on tight.
looks like there is a sensor on the filler cap/lid side.
which is faulty and not sending correct signal to the main computer in the car.
Apr 29, 2017 | 2006 Kia Rio
We have an Surveyor house trailer 3 years old, lightly used. The last time we tried to use the fridge it didn't work. Mod#DM2652 Ser#81708076. Checked the outlet that it is plugged into, it works,...
Since your unit is an AC and Gas unit, you need to find out if it works on gas in order to make a good diagnosis.
But from your description, it sounds like your DC power is not at the unit.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Jul 12, 2011 | Dometic RM2652 Refrigerator
My fridge will only work on 220 volts but not on 12v or gas anymore. the fridge worked perfectly then the gas stopped working one day, i discovered that the gas pipped was blocked, after unblocking it the...
Your refrigerator has a freon that we call R-717 which is amonia. You have to heat the amonia to have refrigeration. using the 12 volt side will cause power drain on batteries. If you had to close the gas valve most of the way down this is telling me that he gas pressure regulator went bad. The 220 volt heater is still working that is why this is working. change the regulator and you should go back to gas for operation. If the helps give me a rating please. thank you.
Apr 08, 2011 | Refrigerators
Engine light came on
Make sure your gas cap is tight, at least 5 clicks, sometimes a gas cap that doesn't seal tight will trigger the Check Engine Light. If the light stays on you will need to pull the Trouble Code from the ECM (Computer) using a OBD II scanner.
Jun 16, 2010 | 1999 Toyota Camry
Breaker swith for freezer keeps popping off.
it can be the defrosting element or a fan if frost free or a motor down to earth disconnent one by one
Jun 17, 2009 | Sub-Zero 685/S Stainless Steel Side by...
Frigidaire Freezer Buzzing
thats not a valid model number open the fridge door and look up at the top by the light bulb on a white sticker and ill try to help ok
Apr 02, 2008 | Refrigerators
Dometic RM2852 Refrigerator Logo
419 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
