Question about Briggs & Stratton 190cc 875 Series OHV Walk Behind Lawn Mower Engine 25mm x 3532Inch Length Crankshaft 12S5020025B1
I have a 190cc B&S lawn mower that was running
I have a 190cc B&S lawn mower motor on a Troy Bilt 2 in 1 frame that was running fine for about 15 minutes then it just died. Tried to start it again and it would only run for 2 - 4 seconds repeatedly and die again. Checked usual things; fuel line, carb filter, spark plug - all seem fine.
canbruce75
  • 1776 Answers
SOURCE: I have a troy bilt mower with a briggs &
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Posted on Jul 19, 2009
mowerman1857
  • 389 Answers
SOURCE: white smoke and oil spewing out of troy built
Check your oil level. If it is way over full, smell it to see if it smells like gasoline. If it does, you have a carburetor leaking gas into the engine crankcase. If you recently had the mower over on its side for blade changing or inspection, you have gotten oil up on top of the piston and it should burn off in a few minutes of running. Check your air filter to see if it is soaked with oil, replace it if it is.
Posted on Sep 19, 2009
kel1guy2002
  • 3740 Answers
SOURCE: My lawn mower Troy built B&S 6.50hp/190cc won't stay running.
Actually there is still something blocking the carb jet inside the float bowl or... there is a bit of debris in the fuel air mixture screw / needle jet on the side of the carb. This happens more than you would tend to believe on a rfecently cleaned carb. A piece of loose / floating debris gets sucked into the already cleaned carb and blocks a passage.
If you leave the choke on it will probably run but as soon as you take off the choke it dies. i.e. blocked fuel passage somewhere.
Kelly
Posted on May 01, 2010
ftw1952
  • 10319 Answers
SOURCE: Engine won't stay running
check the fuses which are under the seat
Also it will not run unless the parking brake is set when your not setting on the seat
Posted on May 02, 2010
  • 3 Answers
SOURCE: Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
Posted on Dec 16, 2010
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt lawn mower
check to see if spindle bearings or bad or a bent or split pulley or bent or twisted deck or for broken lawn mower frame uallaslly around a weld frame twist deck belt comes off
Jul 10, 2013 | Garden
Troy bilt lawn mower were spark plugs go in striped and wont tighten
you can get a spark plug thread repair kit at a auto parts store
Aug 12, 2012 | Garden
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Need owners maual
Contact Troy Bilt directly and request one.
Jan 09, 2012 | Craftsman Garden
How maintenance Troy bilt, 6.50 190cc 21" 2 in 1 push mulch mower with rear bag?
my troy-bilt 21" mulch mower 6.50hp/190cc won't start after it run for any amount time.
Sep 05, 2010 | Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Briggs & Stratton 190cc 875 Series OHV Walk Behind Lawn Mower Engine 25mm x 3532Inch Length Crankshaft 12S5020025B1 Logo
109 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
wadingriver
wadingriver
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
