Ritetemp 8022c cant get air to turn on even after reset can it be fixed
I have a ritetemp 8082C, how do I open it to replace the batteries?
To replace the batteries in the Ritetemp 8082C thermostat, first switch the Mode switch to Off and the Fan switch to Auto (if they aren't currently in that state). Press up on the catch on the bottom of the thermostat and swing the body of the thermostat away from the back plate on the wall. The lift up to remove the body of the thermostat from the base. Turn the body of the thermostat over to see the battery compartment at the top of the back of the thermostat.
This is shown in the installation manual in different sections. Removing the body is shown on page 3 (page 4 of the PDF). Changing the batteries is shown on page 6 (page 7 of the PDF). Ritetemp has the manual here: http://www.ritetemp-thermostats.com/80XX/images/8082C_installation_guide.pdf .
I hope this helps.
Oct 28, 2017 | Heating & Cooling
Ritetemp 8022c
After you program the thermostat..the temperature numbers stays on the screen a few seconds then starts to indicate the temperature of the room. This is normal.
Nov 29, 2013 | Heating & Cooling
Ritetemp 8022c
no you can not , overwrite in same microcontroller
Oct 12, 2013 | Heating & Cooling
My thermostat is not working properly.I took off the plate, and connected the rh wire to the w wire, there is a spark, but heat still will not come on. should these wires both be connected to the rh...
The rh and w wires should not be on the same screw. That would make the heat run all the time because it would bypass the thermostat. It sounds like you had power on the rh wire which is the hot wire from the transformer. If you connected it to w and the heat still didn't come on then your problem isn't the thermostat. You should check the contactor or relay that makes the heat kick on. I don't know what type of system your thermostat is controlling so I can only give you limited advice on that.
Nov 14, 2010 | Heating & Cooling
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
Ritetemp 6022 programmation manuel Where can i
when the furance turns on it never shut off. how can I fix this.
Dec 08, 2009 | Heating & Cooling
I have 2 seperate controls ,1 for heat the old honeywell round turn styls and then i bought a new digital thermostat ritetemp and i have 3 wires for the airconditioner white,red and green, i just cant...
on the round its r g w hook that on the new stat if your using it for heat to then the rh and w are heat controlling baseboard or a boiler relay? the new stat has a jumper wire remove that it is hooked up to rh and rc un plug every thing good luck Tom
Jul 03, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
308 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
