Question about Samsung Televison & Video
Samsung LE32M87BD picture settings - can you point me in the direction of the most suitable settings, please?
  • Anonymous Sep 23, 2008
    I have a problem with white and black colours being blotchy on the same model. Is there some kind of setting I can change to get rid of this... please?
    Thanks
Red, blue and green lines effecting the picture on the screen, making visibility difficult. what could this be?
Let me ask you a few question please. Is the picture also bowed. when television have the multcolored effects it points to a problem with what is know as convergence cuircits. The second question is when you go into setup menu under customer menu setup can you locate convervgence options. I ask this because these set have a common problem in this area. You might read this article it might point you in that direction .http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in (fl231 fuse problem) let me know and i will see what i can do to assit you
Feb 05, 2011 | RCA R52WH73 Projection Television
What is convergence
Convergence, is whereby a device combines a number of Beams from a source to a Point, that is suitable for use. It is sort of like a Focus, but for multiple beam sources. They converge, they all come into one point.
Feb 10, 2010 | Sony KP-51WS500 51" Rear Projection...
I just hooked up my new Samsung 55" LED LCD TV it has 1920 X 1080 resolution and 240Hz speed. Initially the picture quality was fantastic, sharp clear great colors...almost jumped off the screen at you....
Try the Direct TV connected to the TV via component cables and see if the picture is clear and stable at the same time. If it is normal check the Samsung website for support on your model of TV to see if there are ANY known issues and or software updates. Please take a moment to rate my answer. Thanks..
Nov 26, 2009 | Televison & Video
The screen blinks flashes blue then goes black and shuts off. Then the red light blinks 8 times.
This is a very common issue with these sets. The issue is the CRT's have cathodes that are shorting out. Right now you may only have the blue one failing, but sooner or later the green and red will follow. The CRT's (picture tubes) are no longer available for replacement individually. At this point you have to replace all three CRT's with suitable substitutes. The part numbers I have included. this is not a do it your self repair as you are dealing with replacing CRT's that can and do store charges up to 1,000 volts. Please take a moment to rate my answer. Thanks....
RED CRT A-1502-023-A
GREEN A-1502-025-A
BLUE A-1502-024-A
Nov 24, 2009 | Sony KP-51WS500 51" Rear Projection...
My yamaha dv-s5650 is only playing in black & white!
That's a problem with the video IC it might shorted. You need to send your TV now to the nearest electronic repair center and have it fix there.
Jun 29, 2009 | Televison & Video
Darkerning picture
Please replace Lamp in TV and lamp replacement procedure is written in instruction manual if you want to do it yourself.
Feb 04, 2009 | Samsung HL-S5087W DLP TV
Samsung HLP5063W-Picture Dropping Out Using HDMI
is the eprom settings set correctly for the input beeing used,you must enter the service mode to inspect and adjust the settings,call your local dealer for assistance.
Sep 12, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
My picture has a "glow" to it
try to adjust your back lighting settings
Jan 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
When i turn the power on it looks like the tv is going to come on but the lamp lite (on display) blinks and then goes out. the screen takes a little bit of a glow but no picture. all display lamps go out...
The place you purchase the set from has to help you or guide you in the right direction so you get the set service, if they dont tell them you will bring the setback to them for a refund or exchange,the manufacture is the responsible one but stores also have something to do.
Oct 01, 2006 | Samsung HL-R7178W 71" HDTV
Televison & Video Logo
171 people viewed this question
cce772000
Level 1 Expert
