Question about Sony Playstation 3 (PS3) Console
Everything connected, the screen shows but the
Everything connected through av, the screen on the tv shows playstation but the screen keeps jumping, what do i do
    Guru:
  • 352 Answers
Try connecting the PS3 to your TV through a different port. For example, if you are using HDMI1 on your PS3, try HDMI2 or HDMI3.
Try a different cable. If you have a friend with a working cable try that.
Try a different output on the PS3. For example, if you are currently using the HDMI port, see if the standard composite or component output will work.
While convenient to plug things into an AV reciever, I find that just adds another link in the chain of devices that could go wrong.
Good luck.
Posted on Jul 14, 2010
PS2 is running but doesn't show on screen
Try it on another TV and see what happens.
If you can use another av cable with the PS2.
Ref: http://support.us.playstation.com/app/answers/detail/a_id/119/kw/no%20video
Dec 20, 2012 | Sony PlayStation 2 (PS2) Console
Doesnt show up on the television. It does turn on. turned playstation on and off, tried different connections, still nothing
It is likely that the problem is your AV cable. This cable has one plug that connects to your Playstation 3 and a red plug, a white plug, and a yellow plug that connects to your television. Follow these steps to get your PS3 up and running again
  1. Unplug your AV cable from your PS3 and T.V.
  2. Plug in your AV cable to your PS3 and T.V.
When plugging your AV cable back into the T.V. make sure that the red plug is in the red socket, the yellow plug is in the yellow socket and the white plug is in the white socket.
If problems persist try using a different AV cable.
Jun 13, 2011 | Sony Playstation 3 (PS3) Console
Av connections not giving signal to tv on PS3.
Turn the power off on the switch on the back, and then back on again. Hold down the power button, keep on holding it down after the first beep, but let go once another couple of beeps sound. It should then take at max a minute but then it should show a screen set up section.
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
Powers on but nothing happens
It happened to me too. When you plug in your av cables and are ready to play, follow these steps. With your PS3 off (Red light on), Press and hold the power button on your console. (Do not use the controller to turn it on.) Keep holding the button until you hear a second beep. (it takes about 2 to 3 seconds.) You will notice your screen flickers, then your PS3 will show up on the tv. All you did was reset the PS3 display settings. You can always go back to HDMI or AV cables. Have Fun.
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
Cant see screen
Make sure the setting on the AV cable is set correctly. Either for HDTV or standard TV. Put your TV on the correct output channel for your connection.
Feb 01, 2009 | Microsoft Xbox 360 Console
Cannot find AV Channel on new Goodman LD2245WD to play playstatio
Check the the color system of the tv.if the tv is auto no problem
video out from playstation to video input in tv.if this is made right with proper wire.it should funtion
Please Don't Forget To Rate "FIXYA" Me For The Help
Dec 21, 2008 | Televison & Video
PS3 will play on AV but will not in HDMI
  1. Connect via AV and turn on the system.
  2. Go to Setting and then Display setting
  3. Select the connector type on your TV.
  4. After you selected connector your TV screen may go staid black. Try to hook your HD cable while the system is still on. (This step should be done in 30 sec. If not, will go back to previous screen)
  5. Your TV Screen should be on via HD cable
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
Playstation wont connect with av cable
is it just the tv screen saying no signal? if so you may still have your tv in HDMI mode if not then you need to go into the television settings
Dec 03, 2008 | Sony Playstation 3 (PS3) Console
White lines and buzzing sound
hey guys i was havin the same issue..... umm i live in toronot ontario canada so are cable is rogers... i disconnected the cable that comes from them and it worked no buzzing sounds and no lines... so that is the main problem i was havin :P good luck
Oct 06, 2008 | Sony Playstation 3 (PS3) Console
PS3 - Screen Flicker
You need to try a new HDMI cable.. Cheap HDMI cables do that? I had the same thing happen to me... I switched the HDMI cable and it fixed mine.
AV
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
195 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
