Question about GE JKP15 Electric Single Oven
Broiler element does not heat on ge jkp15bow2bb
Broiler element does not heat on ge jkp15bow2bb. is it the element or the control panel. the control panel was replaced 5 years ago.
    President:
  • 1,891 Answers
Ck the element and witing to control / then go to the control . elements are very common .. mm
Posted on Jul 15, 2010
Broiler will not work on a whirlpool range rf367lxsyo
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Apr 17, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
Nov 21, 2009 | GE Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
GE JKP15 Electric Single Oven Logo
202 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
