Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
The dirtlifter powerbrush do not trun.the belt are ok and i unplug it and trun it back . still not working
  • 2 more comments
  • meme908 Sep 24, 2008
    This machine worked one time...and the brushes turned. When I used it two weeks later, the brushes do not turn....I have tried turning it on and off, repositioning the water tank, etc.
  • jasra1980 Nov 12, 2008
    i have had my bissell proheat 2 for a couple of years and it was working about a week ago. Not the brushes are not turning. The belts are ok intact, I can manually turn the brushes when I flip the machine over to check it, but when I turn it back on it still won't work.
  • Anonymous Nov 16, 2008
    the brushes dont run
  • dekthai99 May 11, 2010
    I had the same problem. The brush is no longer turn or **** the water from the carpet. How do we fixed it then?
I have a Bissell Dirtlifter Powerbrush that will not spray soap. I assume the soap lines are clogged, but how in the heck to you "unclog" them? I've searched high and low on the Internet looking for that answer.......
Posted on Sep 10, 2008
Have a Bissell Dirtlifter Powerbrush that will not spray soap. I assume the soap lines are clogged, but how in the heck to you "unclog" them? I've searched high and low on the Internet looking for that answer.......
Posted on Oct 27, 2008
    President:
  • 1,673 Answers
If the complete unit doesn't run, it could be a bad switch or cord, at least these would be what to check first. If it is the brsuhes that are running, the brush roll motor may be bad.
Posted on Apr 20, 2008
My Bissell will not spray water out on the floor but the hand tool works fine. Need some advice on what to check
First check fluid levels. Check Bladder level is full and Heater tank level. Sounds silly but you never know
1. Check the tank seating. If the tanks aren't seated corrected they won't work correctly. Turn off and unplug unit. Remove tanks and reinstall them.
2. Check filter. It may be clogged. This is the "FLOW INDICATOR". Remove the cap and rotor. The filter is just below the rotor and cleans by back flushing. CAUTION: don't drop it down the drain.
3. Check pump belt. Belt can break and cause the problem. Turn off unit. Turn unit back on and check too see the DirtLifter PowerBrush turns. Refer to NOTE below if brush doesn't turn.
4. Reprime pump. Loss of prime can happen if fluid levels are low. Turn unit off for 1 minute then turn unit on and press the trigger.
For all checks it is best to turn unit off and unplug it. NEVER USE ELECTRICITY WITH FLUIDS.
BROKEN BELT: Turn the machine off and unplug it. Move it to a dry area. You will need a flat head screwdriver.
NOTE:
Insert screwdriver into the lower slot of the belt access door to release the lower snap (on left side of unit as you are looking from the front about an inch up behind the adjustment knob) If necessary insert the blade end into the upper slot to release the upper snap. Examine the belt for breakage. If broken, refer to your User Guide for replacement parts. Installation instructions will accompany the replacement.
Dec 30, 2015 | Bissell 1693 PowerSteamer Upright Vacuum
Can i use this machine to do laminate floors
no not recomendid it will scratch all the laminate
Feb 06, 2013 | Unknown Bissell 2080-3 Bissell...
Water won't come out
Hi there SmartAlec from nelsonvacuums.com.au here. I think that the likely solution for the problem is that the water tank is slightly warped and so will not seal properly. Normally this is caused by using hot water in the tank. It should still be covered under warranty though just take it back to the dealer and get them to check it.
Aug 14, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Bissell Dirtlifter Powerbrush carpet cleaner will not roll. The back wheels roll fine, but when you put the machine down flat, the front part (where the roller is) sticks and will not roll.
I had the same problem. It would pull backwards but not go forward. A closer examination revealed the clear plastic part on the bottom in the very front of the machine had popped loose on one side.
If you look at the front of the machine, there is the clear plastic part on top where you see the dirty water being sucked up. The bottom half that creates the channel for the vacuum is where it came loose. It wouldn't create enough suction to draw the water up either. By taking out the two screws that hold the top part in place and removing it, I was able to snap the bottom back in. Works fine now. Hope this helps.
Apr 14, 2009 | Vacuums
Water will not come out to do floor work
HI, I have a very similar Bissell. My problem was that after unscrewing the top plate and looking at the pipes the pipes feeding the front sprays were full of gunge blocking the sprayheads. I managed to flush it through by carefully removing the T connector that feeds the front 2 pipes, placing it back so it stuck out of one of the holes and replacing the water tank and turning on while holding it over a bucket. Black and white bits came out but it did flush through. I am thinking of doing a youtube video - let me know if this will help you!
Chessvalley.
Nov 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Dirtlifter Powerbrush does not turn
Make the machine safe from the power source first
When you remove the belt access door you are looking at the pump belt,
To gain access to the brush belt you must turn the machine over and remove the brush at the bottom of the machine.
there are two screw in the red retainers at each side of the brush, remove the screws and the retainers and the pivot arms ,you should see the brush belt and the pump
Jun 07, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
1,435 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
