Question about NewAir ACP-1000E Portable Air Conditioner
Loud rattle in a new newair ac-1000e bt
Loud rattle ,when the compressure turns on ,its on a hard level floor
  • 456 Answers
Buy some 1/2 thick rubber pads and put it under the unit, I am assuming it is on rollers or has feet. This should eliminate some of the problem
Posted on Jul 14, 2010
Why is there a rattling sound under my hood after i re charged my ac?
The possible problem here is that you put in too much gas and the compressor pistons are pumping liquid and not gas . This is hammering the rod ends on the swivel plate and if allowed to continue will result in compressor failure requiring a new compressor Have an accredited ac specialist shop check the pressures in the system and adjust to correct levels.
Jul 28, 2014 | 2006 Scion xA
AC is New Air model ACP 1000 E The unit fills up every 5 hours. Is there a way to run the AC without the dehumidifier? The setting is currently on the snowflake.
No, a byproduct of cooling the air is condensation....or dehumidification... so in short.. if you want to cool the air you will also dehumidify it...
heatman101
Jun 15, 2011 | NewAir ACP-1000E Portable Air Conditioner
The air conditioner is blowing hot air, there is no water to drain
if it is also blowing cold air out of the other vents you need to vent the hot air its blowing outside
Sep 30, 2010 | NewAir ACP-1000E Portable Air Conditioner
My NewAir ACP-1000E Portable Air Conditioner says the water tank is full yet it is empty. Any ideas?
Check the float thaat is the sensor to indicate the water level to the micro controller. The wires are cut or the float is deffective .
Check and replace.Credit if helpful with this tip.
Aug 24, 2010 | Heating & Cooling
Setting air condition for 1st time
Check whether you have set the OFF timer.
Check thermostat / thermistor.
May 26, 2010 | NewAir ACP-1000E Portable Air Conditioner
Well my acp-1000e has a error and load beeping noise and wont respond to any buttons, how do i reset it on is something wrong with the unit. please email me jammythebull@yahoo.com thanks
I think it may be a blown fuse.... My unit is doing the same thing except I'm not getting an error code on the display. I opened the unit and checked the fuse, it was definitely blown. I have to wait till tomorrow to get the new fuse to see if that fixes the load beeping and the non-responsive display.
May 23, 2010 | NewAir ACP-1000E Portable Air Conditioner
I'm looking for an owners manual for the New Air ACP 1000E. My wife is a teacher. The school got her one of these for her room, but the custodians took the manual, so when their is an "error" message she...
Thank you for visiting FixYa!
You can view your owners manual at the following website. It's in PDF format. If you need a PDF Reader you can download Adobe Reader for free.
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
http://tiny.cc/fixya838
Nov 20, 2009 | NewAir ACP-1000E Portable Air Conditioner
My 02 sonata a/c system doesnt blow cold?
Ok... you wrote "lock was all dry but after i charge the system it start leaking from the same place that the original was leaking,(center of ac compressure.)" Sounds like you should have 'OVER HAULED' the existing/used compressor before installing it... OR bought a recondition/new compressor (ya think?). It appears both the original and used compressors have the same defect.
Jun 24, 2009 | 2000 Hyundai Sonata
My ac blows hard, added freon, clutch not turning could it be fus
If the blower is working,it indicates your car blower system is ok.If the freon system is contain the correct amount and still clutch is not turning when the A/C switch is in the on position check the supply for the compressure.If there is supply that means the problem with the A/C compressur clutch coil and apply the repair procediure or replace A/C cpmpressure.If there is no supply Check the fuses,wiring system and A/C system pressure switch.
Jun 06, 2009 | 2000 Saturn SC
NewAir ACP-1000E Portable Air Conditioner Logo
188 people viewed this question
Top NewAir Heating & Cooling Experts
gbob59
Tom Chichester
Bill Boyd
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
