Question about Dell Vostro 1500 Notebook
No screen display when i am starting the my system.it not started
    Genius:
  • 1,157 Answers
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 29, 2011
How to get my tablet to start rotating again. It is set to auto rotate but it won't stop working.
This varies by operating system which is why it is a good idea to post the brand, model, and operating system with a query.
For a Samsung Galaxy 10.1:
Type apps is the upper right corner. Then tap Settings from the all tab. Then in the left menu, tap screen. Then, tap auto rotate
For the Inspiron Dell 2-in-1 with Windows 10:
Go to Control Panel> Display>Change Display Settings and then make sure that the "Allow the screen to auto-rotate" is selected. Or try the following: Place the tablet into Pad/Tablet mode.
Click the Start Start menu and select Settings. Click System.
Click Display. Scroll down and toggle Lock rotation of this display to ON.
Or this might help:
Click the Start Start menu and select Settings. Scroll down and toggle Lock rotation of this display to OFF.
Nov 26, 2017 | Tablets & eReaders
My lenovo does not show full screen display
Change your screen resolution in the Control Panel. Click Start/Control Panel or Start/Settings/Control Panel then look for Display or Appearance and Personalization. Open the display and change the screen resolution (it might be under the settings tab depending on your operating system).
You can also Right Click on an open area of the Desktop and select Properties to get into the Display.
Jun 01, 2012 | Lenovo IdeaPad S10e Netbook
My on screen display has gone small
What do you mean has gone small? You mean your icons are smaller?
Try changing your screen resolution. Right Click on an open space on the desktop and select Properties. When the Display Properties window opens select the Appearance tab. Look down at the bottom and you can make sure your Font Size is Normal, if not change it to Normal. Click the Settings tab and change your screen resolution. The higher the resolution, the smaller the icons. Size 1024x768 is what most people use.
You can also get to the display properties to perform the steps above by clicking Start/Control Panel or Start/Settings/Control Panel. Look for Display or Appearance and Personalization. Open it and the display properties window will open.
If you are using Windows 7 you can also just click Start and in the search box type Screen Resolution. Look up at the top for the search results and click on Screen Resolution.
If you can't get it back to the way it was you can try doing a System Restore. System Restore allows you to select a Restore Point (date and time) before you started having problems. So if you display went small yesterday, then select a restore point before yesterday.
System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected). To start System Restore click Start/Program/Accessories/System Tools/System Restore then select a data and time before you started having the issue.
If you are using Windows 7 you can just click Start then in the search box type System Restore and look up at the returned search results and select System Restore.
System Recovery on the other hand deletes everything and sets your system back to when your first purchased it.
May 20, 2012 | HP Computers & Internet
Hello my lenovo laptop is infected cant do anything with it. How can i reformat it back to factory settings Regards
Hello, when starting up the computer hit 'F11' on your keyboard and it should bring you to a screen which will allow you to reset your computer back to it's factory settings with the original Operating System installed and all other software that originally came with the computer.
Please proceed with these steps with caution as all files will be erased.
Mar 05, 2011 | Computers & Internet
Monitor displays "frequency out of range" message.
if the system unit is working while displaying that on the screen.try this:start the system unit a fresh and quickly press F8 button on the keyboard immediately the computer start up for 5-6 times simultaneously and select "boot with safe mode" then after booting u can now readjust the screen resolution from the control panel
Jan 17, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
The screen will not come on
If your computer is starting normally (you can hear the appropriate start up sounds) but you have no display either your screen is broken, it is disconnected, or it has been disabled. Try connecting an external monitor. Function key and F5 often cycles through the available display options.
Jul 21, 2009 | Acer Aspire 5520-5908 Notebook
Dell Inspiron blank screen
You can restore your system in your safe mode.
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Jun 11, 2009 | Dell Inspiron 9300 Notebook
ViewSonic VA720 Screen displays briefly then goes blank.
it looks like the Inverter's gone in your screen, it works like a starter in a florescent tube, it 'kick starts' your screen to come on. Turning it on/off many times eventually 'kick starts' your screen and makes it come on eventually.
Jan 15, 2018 | ViewSonic VA720 17" LCD Flat Panel Monitor
Display problem
next time there are many option beside strat windos normally, first try last known good configuration that worked, if didn't work try saFE MODE AND MAKE SYSTEM RESTORE. GO START>PROGRAM>ACCECORIES>SYSTEM TOOLS SYSTEM RESTORE. you can read about system restore here.
another option is repair windows(you need someone who know to do this or may be try to google it) or last option format it.
Jan 22, 2009 | Acer Aspire 3680 Laptop
HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Dec 19, 2007 | Computers & Internet
Dell Vostro 1500 Notebook Logo
48 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
