Question about HP Scanjet G4050 Flatbed Scanner
Try to scan and get message A required software component was...
Try to scan and get message "A required software component was not found or improperly installed. Please reinstall the software."
Get message when I try to scan a picture, scan film, scan a document, but NOT make copies (that works).
I have updated drivers uninstalled and reinstalled. Same error.
4 Suggested Answers
michael_grey
  • 365 Answers
SOURCE: HP 4570C flatbed scanner. Windows XP. USB
Go to the control panel and look under cameras and scanners.Then look under events.You should be able to figure it out from there.
Posted on Jul 22, 2009
SOURCE: this error will not stop coming up on my computer
Navigate to C:\Program Files\HP\Digital Imaging\bin
or C:\Program Files\Hewlett-Packard\Digital Imaging\bin
Double Left Click on the executable file:
hpqdstcp.exe
You will NOT see anything happen but it will get your program destinations setup correctly and hopefully remove the error. This sometimes happens when you change printers and old stuff stays on your PC.
Hope this helps.
Posted on Aug 30, 2009
firstguy
SOURCE: When I try to scan a document using my HP
After placing the document in HP offficejet pro L7590 then I pressed scan to computer then ok the reply no scan options
Posted on Aug 10, 2011
When I try to scan for channels on pinnacle tv center pro version 4.9 it freezes at the end of the scan & never finishes.
Your setup of Pinnacle TV may has problem in it or if it displays any message, read carefully the message and install any necessary software if it requires in the message displayed.
Aug 04, 2011 | Computers & Internet
Progressive Scan
Try these steps:
Locate the output jacks DVD player. Sometimes they are standard female RCA A/V jacks, like those found on the front of many VCRs. Others are more tricky, having a small jack that looks like a stereo headphones plug. These camcorders require a special cord that converts a 1/8" stereo signal into RCA A/V male plugs.
  1. Using the proper cord, connect your PLAYER to the VCR's RCA A/V input jacks, usually found on the front or back of your VCR.
  2. Turn on your VCR and TV, so you can see the input from the camcorder. You might have to select "Input 1/2", "Line 1/2", or "VIDEO" depending on your VCR model. You should now see whatever is on your camcorder displayed on your television.
  3. Press "Record" on your VCR, then press "Play" on your camcorder. That's it!
Sep 07, 2008 | Samsung DVD-VR357
When i install scanjet 8270 on windows 7 professional.after complete they appear hp solution center on deskotp and photosmart. so the problem is when i try to scan documents or picture or other alse the...
Hi
Please go to the control panel and select the Scanner and Camera, hear you get your scanner, double click the scanner and try to scan the paper, if hear also give the same error then please reinstall your scanner driver,
click hear to download the driver
May 19, 2011 | HP ScanJet 8270 Flatbed Scanner
When i try to scan i get a message that reads " A required software component was not found or was improperly installed. Reinstall the HP Photosmart cd that came with the device". I don't have...
First of all unplug the printer from the computer and then use revouninstaller (use the free version!) to completely uninstall the support software - use medium and it should delete all file and folders.
Switch off the computer and restart still with no printer connected.
Run the software that you have downloaded but do not connect the printer until you are told to do so by the software.
http://www.revouninstaller.com/
Mar 02, 2011 | Office Equipment & Supplies
Will not Scan. Gets message..
Is it installed in windows as a scanner? Dont use scan button on machine try using scanners or document imaging software that needs to be in place on your computer, ie Document imaging in office or scanners and camera in windows, one sends scan signal from the PC, can use the scan button on scanner only when configued to do such. Scanner has software as does the printer both can found at HP web
Nov 07, 2009 | HP Photosmart 3210 Printer
Cannot scan wirelessly from HP Photosmart 4580 wirelessly
I reinstalled the printer software and reconnected the wireless connection and it now works well. I read somewhere that registry cleaner software may remove HP files that are required so this time after the registry cleaner scan, I unchecked any HP entry or printer entry and the scanner is still working, however, only from the pc to the printer, I still cannot scan using the buttons on the printer.
Jun 06, 2009 | HP Photosmart C4580 All-in-One InkJet...
Scanner won't work
try removing the program first then remove the scanner from the computer then turn it off for 60 sec. thenafter 60 seconds turn it back on then connect the scanner again wait for a pop up on the lower right of the screen it will message you that found new hardware then click on it and try installing your software if there is no pop up your scanner might have a problem. hope i help
May 03, 2009 | Computers & Internet
Scanning document/picture problem for attaching to email.
Sounds like a corrupt driver / software install. Try reinstalling the drivers and application software from the disc you got along with the printer.
Mar 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
HP Scanjet G4050 Flatbed Scanner Logo
243 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
