Question about Whirlpool Duet GHW9150P Front Load Washer
F11 code spring broke replaced spring now have f 11 code with humming noise
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%
Posted on Sep 29, 2010
How do you adjust the front springs s0o that the rod wont bnd and break?
Pride Mobility Jet 7 (Power Wheelchairs) - USA Techguide
www.usatechguide.org/itemreview.php?itemid=929
13 posts - ‎11 authors
Anti-Tip Wheels 6&8221; solid; front-mounted • Suspension Limited. ... get either aPride Jazzy, or a Jet 7, you'll be very happy, as long as you can afford a lift ... If youdont, the charge keeps going down, and will not ever recharge back to the ... These products need to be charged about 8 hours a day after usage, so its better ...
Dec 01, 2015 | Pride Jazzy 1103 Ultra Standard Power...
I get a F11 code with beeping noise and the oven controls won't work? what can i do?
Hi Ken Kazemi - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
We are geting a F 11 code on this Model number plgfmz96ecc
Your F11 error code is displayed below. It would be best to have the unit serviced by a professional for this type of fix as if not performed properly, the fix could end up costing over $500.00.
F11
Shorted Keypad.
1. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
2. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
EOC = Electric Oven Controller
Jun 13, 2011 | Frigidaire PLES399EC Electric Kitchen...
I have a Sears Crafstman Garage door wireless opener. Model 139.53615SR . The door hums but nothing happens. The chain doesn't move. The springs on the door broke last year and i replaced both of them....
My plastic gear stripped soon after a spring broke. I think the broken spring put a huge load on the opener that day and ruined the gear. Replacement wasn't too hard. It will be obvious when you remove the cover if the gear is stripped. Here are instructions:
http://tinyurl.com/gearfix
Dec 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Sep 12, 2009 | Kenmore 73952 Gas Dryer
What does F11 code mean?
F11 is a code that referes to communication error between the central control unit and the motor control unit. Disconnect power. Check wire harness connections to motor and control board. Check drive belt, visually inspect to see if belt is broke. Check drive motor, visually confirm motor operation. It is possible that if the belt broke it may have slung around in the cabinet and damaged or loosened the wire harness connection at the motor. Try unplugging wire harness at motor and then plug it back in securely. Hope this info has helped. Thanks, Tim.
Jul 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
CREEKING NOISE CONTD
You have a damaged Strut And possible spring damage.should have been changed when the work was carried out.
May 28, 2009 | 2002 Chrysler Sebring
Humming noise from Steering Wheel
I have frequently run into this problem. The "clock spring" in the steering column has a plastic case (shrinks when cold/expands when temperature warms up). It's a design flaw, not a defect. Replacing the clock spring usually eliminates the noise for awhile, but eventually it returns. It's one of those things that drives some people up the wall, but others just ignore it.
May 27, 2009 | 2002 Hyundai XG350
Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
Apr 03, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Could you tell me what F11 code means?
F11 error code means there is a problem with the Control panel. Could be melted wiring, etc, since you left the oven standing. However, you can try unplugging the device from the power socket for about 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
Oct 13, 2008 | Frigidaire Kitchen Ranges
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
