Question about Frigidaire FWS833A Top Load Washer
Frigidaire FWS833A Top Load... Problem
Won't drain wil spin after i take off the panel locate the pump and then what? unscrew the nozzle connected to the pump?
  • Anonymous Sep 08, 2008
    my machine wont drain -it fill with water and spins but wont drain-what could be the problem and how much to fix
  • Anonymous Apr 25, 2009
    water wont drain? smells like burning? what should i check, if its the belt, where is it? the machine is full of water at the moment.
Lid switch also function as safety lever lock. its a 2 way lever contact switch. replace it.
Posted on Jul 01, 2008
Will not drain
FRIGIDAIRE TOP LOAD WASHERS WILL NOT SPIN OUT WHEN THE LID LOCK IS BROKEN
Mar 20, 2014 | Frigidaire FWS833A Top Load Washer
Spins but wont drain has a slight burning smell
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 05, 2011 | Frigidaire FWS833A Top Load Washer
I have an older gallery model number fws645gfs1 and it suddenly stopped draining and won't spin on any cycle. How can I fix it and is it even economical to bother?
It won't drain so the pump is not working and if it does not spin then there is a problem with your transmission. You did not mention hearing any kind of noise so I will assume that the motors don't work. I think it is cheaper to replace than to repair. Good Luck
Jan 07, 2011 | Frigidaire FWS833A Top Load Washer
Wash water won't drain, machine stops
Unit will not run till most of the water is gone so the pump probably has something it it . Remove front panel(two screws in front at bottom ) lift top by depressing clips in seam between top and front panel lean back. Push down on front panel and remove . You will see pump
Nov 18, 2010 | Frigidaire FWS833A Top Load Washer
Maytag washer
sounds like you're suffering from the pump belt either stretched due to overload and overheating the belt, or the belt is off the pulley.
You can remove the front cover by removing two screws near the bottom of the front panel. Tip the bottom of the front panel outward and then disengage the upper clips as you pull forward. This exposes the pump, motor and you can reach underneath to the pulley and the belt. The motor spring holds the tension on the belt. If the belt is damaged, replace. Check the pump to make sure nothing got sucked inside... Maytag's pump are opaque plastic so you can see inside without removing the hoses... This is usually the reason for a tub that won't spin or drain... Good luck let me know.
Jan 19, 2009 | Frigidaire FWS833A Top Load Washer
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Wont drain or spin
Did you checked the pump ? Does it make any noise ? The washer will not move to the spin stage if water will not pump out from drum.
May 04, 2007 | Frigidaire FWS833A Top Load Washer
Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Apr 01, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
157 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
