Question about Zebra P430i Thermal Card Printer
Zebra p 430 i Printer ribbon is not scencing how to calibrate ribbon in this Printer
Zebra id card machine ribbon cutting problem
Posted on Apr 27, 2011
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
Zebra 105SL runs out of ribbon, the printer still continues to run, have tried calibration, still not stopping when ribbon runs out
Make sure that you have the printer set for THERMAL TRANSFER printing and not DIRECT THERMAL. It is possible to run the printer in DIRECT THERMAL MODE with the ribbon installed so in that case when the ribbon runs out the printer will not stop.
Regards,
mikeo@acebarcode.com
Jan 20, 2011 | Zebra 105SL Thermal Label Printer
Hey.. the zebra printer z4m is sayin "ribbon out" but it doesnt take ribbon. So how do i fix it?
go to the setings, and check Direct Termal or Termal transfer, Have to be Termal transfere, then run manual calibration, if still going, try to go tu Ribon sensor and change the number, possible is to higth 250...?) change to low number, and try to calibrate again.
Nov 23, 2010 | Zebra Z4M Printer
My zebra card printer p330 i donbt recognized the colour ribbo YCMK, only detect the mono ribbon
The P330i is not supposed to work with the YMCK color ribbon, you should use the YMCKO 800015-440 color ribbon.
-- The Pros at www.DiscountIDStore.com
Sep 25, 2010 | Zebra P330i Thermal Card Printer
Hi, My name is Hakan and I'm having trouble with an ZM 400 label printer. My ploblem is that I get Out of Ribbon, Pause in Zebra status Monitor. What can be the problem?
If you are using a colored ribbon it might be too transparent for the ribbon sensor to read. Re-calibrate the ribbon sensor.
If you're using black ribbon and you're sure that it's loaded properly and the sensor isn't being blocked, then print a sensor profile and re-calibrate the sensors if necessary.
Mar 03, 2010 | Zebra 203DPI Printer
Hi, my printer is printing blanks. Windows XP, Zebra ribbon I replaced the ribbon and still no luck. I tried setting the darkness to maximum, but that didn't work either. I tried the "dump"...
The zebra ribbon has ink on one side and the other side has a backcoating which protects the printhead. simple way to check is to peel off a label and momentarily stick to ribbon and remove. This will show you which side is inked.
If ribbon is installed correctly then reset the printer and re-calibrate it. 1. install labels and ribbon 2. power on printer. If you have a solid green light on then 3 turn printer off. 4 hold down feed key 5 power printer on and after 2 seconds release feed key. printer will perform a calibration routine and eventually print out status page. IMPORTANT 6 Hit Feed Key once more. Printer will display Out Of Dump message. Your printer has now been sucessfully calibrated.
May 06, 2009 | Zebra LP 2844 Thermal Printer
Zebra 140Xill problem
Whenever you open the printhead, the Pause led will light.
If you hit the Pause button, the printer should go back on-line and resume printing (if you didn't turn it off).
If that doesn't work, try the calibration button (labels will feed out), then the Pause button, then the Feed button.
If you don't want to toss too many labels when you calibrate, the "maximum label length" (or some name like that) can be adjusted through the front panel.
Label_Guy
Sep 14, 2008 | Zebra Printer 140-751-00000
Zebra P430i Thermal Card Printer Logo
933 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
