Question about Nelson Sprinkler: Traveling Tractor
Will not move spinkler head or wheels - Nelson Sprinkler: Traveling Tractor
    Problem Solver:
  • 5 Answers
My key will not start my car...its in park and the steering wheel is in the lock position...and the head lights aer not working
Put your keys in and try to move your steering wheel only a fraction of an inch. If if moves, hold it there and you car should start.
Jan 13, 2015 | Cars & Trucks
Instructions to maintain a TORO TR50XT Sprinkler
The sprinkler head unscrews just like a bulb. Dig a hole around the head to below the connection.
Unscrew the old one and screw in another one. You might need a nopple on the new head to match the connection. Set up the new head with the same setup an the one in the ground before you unscrew it as water will come out of the pipe and fill the hole. You want to get the new head set before debris gets into the pipe.
Jul 05, 2014 | Toro TR50XT-HP, Adjustable Arc, 12 Inch...
When power applied print wheel and ribbon lift works ok. As printhead starts moving to left margin it will start moving and then and stop and just hum or buzz until power turned off.
Move the head back and forth by hand W/power off, look for debris in the printer area, put some WD40 on the silver shaft that the head slides on.
DickyO
Aug 04, 2010 | Lexmark Wheelwriter 1000 Typewriter
Model 6784 -wheel won't spin
The wheel is probably moving but the print solenoid cap is probably broken. We sell them with installation instructions and shipping for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Jun 02, 2010 | IBM Wheelwriter 6 Typewriter
03 Kia Rio- can not get retaining screws off rotor...screws now stripped
hi from uk the retain screws are for holding the rotor/disc in position so when wheel bolts are removed they can be easily refitted as rotor will not move off line the screws play no part in brakes and the wheel bolts or nuts are what secure the wheels and rotors in place SO if screw head has stripped ? you can use a drill with bit size of head of screw and drill the head off screw then remove rotor you can then try vice grips to remove screw but if not possible you can fit rotor and reassemble brakes hope this helps
Jan 28, 2010 | 2003 Kia Rio
My Polaris 380's wheels have stopped moving or move at a very,very slow rate. The pulleys are fine, the inline screen is clean, the booster pump is fine.
remove the backup valve temporarily and note action. If improved - replace valve. Also check head float for water. There should be none present.
Aug 08, 2009 | Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL...
Need to know how to adjust the rubber drive wheel on a rear engine snapper. Any help will be great. Thank you
Usually just replacing the drive wheel will fix the problem. There are two allen head set screws on the disc mounted on the engine shaft visable through the hole in the rear of the mower. However, don't expect when you loosen them that the disc will move up or down freely. I've only ever move one by taking the engine off. I'd try replacing the rubber drive wheel first.
Jun 14, 2009 | Omega Rear Drive Wheel Snapper Mowers
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Nelson Sprinkler:  Traveling Tractor Logo
180 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
