Question about Philips 9P5544C 55" Rear Projection Television
Picture on my magnavox 9p5544c102 is fuzzy with green tint
Picture on my magnavox 9p5544c102 is fuzzy and has green tint. When I go to adjust color, Red doesn't show up at all. Where do I get replacement parts, and what needs replaced?
  • Philips Master
  • 8,617 Answers
Its the CRT coolant which needs replacement. You can get the Phillips CRT coolant kit at www.tvrepairworld.com which contains the Coolant for all three CRT's plus has the CD with instructions.
Posted on Jul 15, 2010
Pictur is fuzzy and green asround all charactures
If the Green appears to be " Glowing" around objects and the color tints are all wrong then its most likely a CRT coolant issue. If the picture appears as 3D with a possible arc in the screen then you can assume its a convergence issue.
Jun 21, 2010 | Philips Magnavox 51MP392H Rear Projection...
Green tint to screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2010 | Hitachi 42V710 42" Rear Projection HDTV
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
My Philips magnavox 64 inch big screen tv has a green tint to it and i cant adjust with any of the color or tint options..
have the glycol ethelyne changed in your color guns, couple hundred bucks. i tried it myself and ruined my tv
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
Magnavox PTV910. The picture is good but color is bad
the coolant in the blue and green crts has congealed which is causing the red tube to become dominate. The coolant can be changed at home. You can get the phillips coolant replacement kit at the following link which contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Jul 15, 2009 | Philips Magnavox 9P6034C 60" Rear...
The color is bad
my rear projection Phillips TV Picture has a green tint.
Jan 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Dim picture
If decide to do yourself, ya only have to do the green and blue ones, the red light spectrum won't allow fungal growth. Pull whole CRT assembly out to prevent spilled/leaking glycol from onto lower main boards
Sep 04, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 9P5544C 55" Rear Projection Television Logo
238 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
