Bowin SLE 2 Heater - red light flashing ''refer to manual''
We don't have the manual - can anybody help us with this?
2 Suggested Answers
  • 81 Answers
SOURCE: I have a bowin gas heater and no instruction
The remote may need a battery. A watch shop should charge 5 dollars to put one in - if it does not work they should not charge you. You can get new batteries for your car remote / watches etc
Posted on Jul 15, 2011
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
What's your problem?so a few days ago on my GMC Acadia 2008 SLE the panel where i control the AC/Heater stopped working, the display is on, but the buttons are not working and dont light up, does
You might just have a wire loose somewhere. My 96 Cadi did that a couple of times lastyear, then it was fine. Hasn't done it since.` So, who knows! Sorry, not much help to you.
Feb 08, 2013 | 2011 GMC Acadia
Does anybody out there have an owner's manual for Lifetime Furnace Model # 1500 VI by Del Rain?? PLEASE contact me!
I have used one of these for years and was looking to find a new one and came across your question. I don't have the manual but here is how the programming works:
On/Off (obvious)
Heat/Fan (if lit it makes heat if off it just runs fan)
Auto/Manual (if off the temperature slider causes the fan to run on high or low)
Preset on (I don't use this but probably can be used to set it to turn on after a selected number of hours)
Preset off (if lit the heater will turn itself off after the number of hours shown on the right)
Time select (press this button to change the number of lights shown vertically ... each is labelled and you add them up to get the hours you want from 1 to 15 ... so if bottom two numbers are lit (1+2) then heater will run for 3 hours then turn off)
Feb 17, 2012 | Del-Rain 1500-V 1500 Watt Ceramic Heater
The clean filter light is flashing on my Bowin SLE2 however the only filter i can see at the back is dust free? Where else might there be a filter?
It should take just a min to remove it and vacuum it. If it will start with the filter out try and see if the light still blinks
Jul 27, 2011 | Heating & Cooling
I have an Rinnai Avenger 25TR heater. The problem is that the heater ignites, it starts, but then it turns off. A red light then flashes and the number 13 also flashes in the bottom right hand corner of...
Paul, the Error Code Fault 13, indicates a Combustion Control Fault. This could mean, not enough gas for safe combustion or to much gas for continued operation. In any event, if requires a service call from an authorized Rinnai Service Technician to solve.
Just in case you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/CI_Avenger_Blaze_Dynamo_Enduro.pdf
Hope this helped you.
Jul 18, 2011 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
I have a bowin gas heater and no instruction manual. The LCD display on the remote is not working. How do I fix this?
Jul 13, 2011 | Heating & Cooling
I have a duraheat 125,000 btu auto start (salamandar) with thermostat that was used once time last spring. it won't start and my husband tossed the box and yes..insructions in the fall. starting...it...
Here is a link to the Owners Manual for your Dura Heat Model DFA-125 forced air kerosene heater.
In addition to how to properly operate it and perform routine maintenance, it has a trouble shooting guide, which should be of great assistance.
You can download and print this manual for future reference.
http://www.worldmkting.com/documents/DFA4560125_EN_SP_FR.PDF
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Red dye reduction
You can find your manual here....www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
AUTO FLASH:
Automatically fires in low-light and backlight conditions.
RED EYE REDUCTION FLASH:
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
camera.
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
Sep 30, 2008 | Olympus Camedia C-725 Digital Camera
Heating & Cooling Logo
251 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
