Question about Eforcity E(220901) forcity Digital Camera BATTERY CHARGER For Olympus LI40C LI40C
Battery Charger I ordered a Battery Charger for my Canon Rebel Digital Camera, and the one you sent me is not for the BP-511 battery. The one you gave me, only has two pins for charging, I need four! Digital Camera BP-511 Compact Battery Charger Set
Battery door latch broken
look for a Canon eos 300D battery door (they are the same camera just came out in different countries) or buy of ebay a cheap broken 300D and salvage the parts that way.
Mar 21, 2013 | Canon Eos Digital Rebel Ds6041 6.3 Mp...
Tip
Canon BP-511 Battery Maintenance Tips
battery info via:
http://www.sales-battery.com
http://www.global-battery.co.uk
Canon digital cameras come in several different lines, some compact for easy travel and quick pictures, and others larger with multiple lens options and more power. the same problem many users have to encounter is the battery.manufacturers will tell to them how numerous hours that Li-ion notebook battery can last, however, they don't tell you how to maintain the battery.
There are more tips for you to change a common battery life, extend it for digital camera. One more simplistic method of increasing the lithium ion battery life by defragmenting the disc and remove excess folders. The suggestion for keeping your device for canon digital camera run powerfully with the hi-capacity canon bp-511 battery, which is a replacement battery, can be used recycled.
A lithium-Ion battery for canon bp-511 has internal circuit board with chips that allow it to communicate with the digital camera to monitor battery performance, output voltage and temperature. It also gives the notebook much more accurate 'fuel gauge' capability to determine how much battery runtime is left before the next recharge is required.
The battery for bp-511 battery provides uninterrupted reliable performance for the canon digital camera no matter you are on the trip or on the train travel, and want to record the sight.
This least quantity of time draws a considerable effect on the complete replacement battery life existence, the lithium ion bp-511 battery is 1600mAh, in fact if the battery can be used correctly, the performance of the battery can be used as the original battery, just depends on yourself. When in the hibernate mode in & out are extremely favorable and efficacious than the usual start & shutdown operation.
Talk about the battery storage, storage the battery in the normal temperature. When in hibernate mode the shutdown procedure grants a alternative to pause present work immediately with the power-off and when in start up activity it will keep on with in a few seconds entirely, As a result hibernate mode saving power. Do not modify or disassemble the canon digital camera battery under any circumstances.
Do not store a replacement battery pack near chemicals and in a damp area as this will reduce Notebook battery ability. The replacement battery is made with chemical material, take care of it, if you can.
more canon camera batteries discount now,like
Canon nb-8l Battery US $ 10.54
CANON NB-5L Battery £ 8.58
CANON NB-4L Battery US $ 6.71
CANON NB-3L Battery US $ 6.71
CANON NB-2L Battery £ 8.48
CANON np-e3 battery £ 21.52
on Jun 04, 2010 | Cameras
I have a Canon Rebel XTI and it was working fine until one day it just decided not to turn back on. Tried charging both batteries multiple times and upon putting them in, it still will not turn on. Am I...
Sorry to hear about this. I have a similar camera and have been racking my brain about this...
My only thought...are you using the same battery charger? Perhaps the battery charger is to blame. You may be out of battery on both batteries. When you install the battery, does ANYTHING happen? Does it say, LOW Battery or CHANGE the battery? Or is it totally black? If nothing happens at all, you should probably contact Canon directly. Or purchase a new charger and see if that fixes the problem.
Canon Customer Support Center Phone: 1-800-OK-CANON
1-800-652-2666 Hope this helps!
Jul 26, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
I have a canon EOS Rebel DS6041 and need to know what batteries I need If you could help please
Here's a page from an excellent forum "Steve's Digicams"
http://forums.steves-digicams.com/general-discussion/84527-canon-rebel-ds6041.html
As it explains, it basically a Canon EOS Rebel 300D and so uses the same accessories.
Here's a url for the Manual :-
www.cleaningdigitalcameras.com/pdf/EOSDR300DIM-EN.PDF
Here's a site for accessories:-
http://www.digitalmediastore.co.uk/Accessories.aspx?Model=DEV_CA_EOS300D
Said site mentions you want a Canon BP-511 or BP-514.
You can find them almost anywhere, Canon site/shops, ebay, amazon etc.
Good Luck.
May 29, 2011 | Cameras
Not charging video will not eject
CANON MV630I battery Specs:
  • Cell Type : LI-ION
  • Volts : 7.4V(Compatible with 7.2V)
  • Capacity : 4400mAh
  • Average Run Time :2-4 hours(minimum)
  • Color : GREY
  • Dimension : 55.10x38.20x39.90mm
  • Net Weight : 146.00g
  • Cpmpatible Model:
  • canon 5797a007, canon 5797a010, canon bp-508, canon bp-511, canon bp-511a, canon bp-514, canon bp-522, canon bp-535, canon pc511, canon vcn009, canon vcn009s, cta db-bp522, delkin dd/bp522, duracell drc522, empire bli-193-2.4, energizer er-c600, gp vcl008, hahnel hl-522, hama 46810, hama cp-810, optex li36, polaroid pr-522l, rayovac rv5462, sakar bp-522cl, sunpak hl-522s, techcell l522us, vivanco bp-22672decf09.jpg
    Jul 22, 2010 | Canon MV630i Mini DV Digital Camcorder
    My canon don't power on with a battery but power on with a charge can you help my to now what is the bad fuse? thank
    try a new battery pack or let your's charge for 12 hres
    about ;its seems that the battery pack you have is low in charge;because if its works with the chargerit should works with battery;about the bad fuse if it was the problem ,the camera will not work at all,
    and that is a big problem that fuse is inside the camera on the pwr board,
    hope that will help.
    May 07, 2010 | Canon FS200 Flash Media Camcorder
    Digital Rebel Canon Camera won't power up
    The cold probably does relate to the problem -- when the camera gets cold, then comes inside, condensation (water) collects in lots of nasty places, including the battery contacts. Water can cause all sorts of problems that result in a poor connection between the battery and the camera. The smell is a result of an arc (spark) -- not good, but sometimes fixable. There is probably something like rust (most likely oxidized copper or aluminum) on the contacts. Something rough like a metal nail file should help remove the oxidation (rust) -- turn the camera upside down so the powder falls out. If you can clean off the contacts so they are shiny again, and also on the battery contacts, you might be back in business.
    You may need to replace the battery -- if it has shorted out, chances are it won't recharge properly. A BP-11 battery (doesn't need to be Canon branded) is around $15 or less. However, if the battery charger says the battery is charged, and there's no evident oxidation on the contacts, battery is probably fine.
    It could be worse. If so, a local camera shop can probably give you the bad new more gently than I :-{
    Jan 12, 2009 | Canon Rebel XT / EOS 350D Digital Camera
    Bp 511
    The BP-511's that are on my shelf are all 7.4V. The worst that could happen if you try the 7.2 in your camera is that it just won't work. I can't see that it could do your camera any harm.
    Jun 20, 2008 | Canon Digital Rebel / EOS-300D Digital...
    Eforcity E(220901) forcity Digital Camera BATTERY  CHARGER For Olympus LI40C LI40C Logo
    81 people viewed this question
    Top Eforcity Cameras Experts
    Steve
    Are you an Eforcity Camera Expert? Answer questions, earn points and help others
