Question about Crave Entertainment Brunswick Pro Bowling for Nintendo Wii
How do you get all 10 pin on spot on a2 pinsetters I can get the 1 7 and 10 on spot but the 8 5and6 are off alittle
AMF 82-70 pinsetters
What make, model and year is this vehicle?
Oct 22, 2016 | Cars & Trucks
If the squares of the three sides of a right triangle add up to 200, what is the length of the hypotenuse?
a2 + b2 + c2 = 200
a2 + b2 = c2 c being hypotenuse
sub c2 for a2 +b2
you get
c2 + c2 = 200
2 c2 = 200
divide by 2
c2 = 100
c = 10
Aug 26, 2015 | Office Equipment & Supplies
Front end shakes alittle when driving over 40 till 75 tires are not the best could it be old out of round tires
Have the tires inspected and rebalanced. As tires wear, the points at which they first were unbalanced have now worn and other spots may throw a little shake at higher speeds. The tires should be balanced every 15,000 miles or at least checked. By that time you should be on you third tire rotation(every 5,000). This will also help pin point any trouble spots or potential failures in the tires, brakes, or suspension(since they should be looking while the tires are off). But don't assume they are telling you the truth. If they wont show you, it isn't true! Plus don't feel obligated to have it repaired there. Get a second opinion if that makes you feel more comfortable. You would with a doctor. Be the advocate for your car!
May 07, 2010 | 1998 Hyundai Tiburon
My Minolta DiMage A1 displays "no card" when memory card is inserted. It's not a new card...it's the same 128mb card I've used since I bought it. Any suggestions?!
If you're lucky, the CF card is faulty. It's going to be a very old card now if it's the original one supplied/bought with your A1. You've never upgraded to a larger card in all this time so it suggests you've never needed to. 128 and 256mb cards are virtually worthless now, so I'd be amazed if you couldn't get one for free via Yahoo FreeCycle. You can also try reformatting your card in a card reader/writer, but A1's and A2's often won't recognise a card formatted in this way and it can render them permanently unreadable by all A1/A2/A200 cameras.
If you're unlucky, then you've bent or broken one or more of the pins inside the card slot which connect to your card when you insert it. To check, get a bright torch and look down inside the card slot. Any bent pins will be self evident as there should be a neat double row of pins and missing pins will show up as gaps.
If you have bent pins then you've nothing to lose by trying to carefully straighten them, if you can't or if the pins are broken, then your camera is effectively irrepairable. Scrap A1's and A2's can both provide the part, but retreiving them from the donor camera is really difficult and so far I've never managed to refit one successfully and I've done a few now. A pro repair is simply not cost effective, especially when a perfectly good used A1 goes for around £40-£50 and the better A2's go for around £80-£100. If you're in North America you can expect prices to be even lower.
Jun 24, 2009 | Konica Minolta DiMAGE A1 Digital Camera
915PL-A2: no post, no beep, no keyboard lights
You may have a short between the board & the case. (check it).
Even if this means removing the board. That clicking you hear through the speakers suggest a short. Make sure your using (Stand offs) which keeps your board off the case's mounting surface. Check the back plate so the tabs are touching the ports comming off the board for good ground.
Double check the you have fully connected both the main power ATX_ 20 pin power connector & the auxiliary 4-pin power
connector. pg. 10. Connecting 20/24-pin power cable Remove & re-seat. If your PSU has a 20 pin connector make sure you connect the cable from the correct end.
Without POST you will not get video to load. Reset your bios
pg. 9 in your manual. Re-enter your bios and setup the bios settings for your board.
Let me know if this helps you reach POST?
Mar 14, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
No post, no video
get some cheap PCI card plug it in. get to the bios make sure integrated video is selected. Speaker connector is two pins in various motherboard the pins should be located close to the reset and power pins.
Oct 26, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
No post beep, no video
had a similar problem with a box i built. Your power supply has two connectors. One long one and a 4 pin connector. Make sure that four pin connector is connected.
Oct 25, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
Ecs 915pl-a2 v3.1b
Check this out http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=533&DetailName=Specification&MenuID=44&LanID=0
Oct 19, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
What types of metering methods are available?
Multi-segment metering (300 segments), Center-weighted metering and Spot metering are selectable. The position of the spot metering area can be specified at the center of the live image or linked to the Flex Focus Point.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Crave Entertainment Brunswick Pro Bowling for Nintendo Wii Logo
Top Crave Entertainment Video Game Consoles & Games Experts
James Wishart
Are you a Crave Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
