Question about Samsung Televison & Video
I need to replace fan 2 but do not know where to find it. Can you help?
FAN NUMBER TWO IS THE ONE IN THE MIDDLE IN FRONT OF THE CROMED BOX DMD IT IS NOT YHE ONE BESIDE THE LAMP OR BALLAST
Posted on Jul 16, 2010
Replace the fan belt 2003 chevy tracker 2.0
Jerald, You will have to remove the the accessory belt first I believe by putting appropriate wrench on tensioner and pulling tensioner toward passenger side to allow removal of the belt. Then you will loosen alternator to let tension off fan belt and replace the fan belt. Reverse procedure to install. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2002 Chevy Tracker 2 0L 2 5L Serpentine Belt Diagram serpentinebelthq com
https://answers.yahoo.com/question/index?qid=20060822210207AA9Tfgo
chevy how belt tensioner works Google Search
Jun 15, 2016 | Cars & Trucks
Need to know where the fuse is for the fan by the radiator. I know where the fuse box is at because mercury sable has 2 boxes. Which one contains the fan fuse. My fan is not working and been replaced and...
You have a relay there are 2 speeds low speed and high speed this is controled by a cooling fan module if you changed fan and it does not work then you will need to check the fan module, first the relay its in the engine fuse junction box High speed is marked on the relay C1056 and low marked C1058, here is what you can do go to the high spped relay open thhe cover and expose the relay with key on collapse the relay does the fan come on? if it doesnt replace the fan module if it does you will still have to replace the fan module here is the location is at the radiator on the front (may be under shroud)
Jun 08, 2011 | 2003 Mercury Sable
Cooling fans not turning on
Hi.
This could be due to several problems.
1. Cooling Fan Relay needs to be replaced.
2. Fans need to be replaced (due to burned out Fan Motor)
3. Broken Wiring between the Fan(s) and Relay
If you would like information on testing and/or replacing any of these components, please let me know.
Thanks...
www.wiring4cars.com
Dec 08, 2010 | 2002 Chrysler Town & Country
Fan noise in left ceiling speaker, how do you fix this problem
ARE You talking about right above your head in the headliner? this is actually a fan to help vehicle know inside temperature. they will come loose sometimes and make noise need to drop headliner down and see if you can reattach may need to replace fan,it is a 1-2" speaker cover in headliner
Sep 29, 2010 | 2003 Chevrolet Silverado 1500
My Surround sound DVD player SC-PT450 is displaying the fault code 'F61'. I have a basic electronic knowledge. It says in the manual to check the speaker wiring, but I have removed all speakers and the...
Panasonic error code F61 is for an output /power problem. Most likely it will need the output IC replaced. But check that the fan(s) are running a bad or stopped fan will also cause F61.
So the fan needs to be replaced. My system had the same problem and the fan was making a terrible noise. I had this repaired and the system is as good as new.It is better that you take it to the technician for the repair.Still then i am giving you little help.Remove the cover and use an air duster on the fan. This may not be enough so if you must, remove the fan (two screws + 2 clips) and pop it out of its housing. Dust the blades off and gently pull the fan away from its center as if you were trying to separate the two. There should be about a 2 or 3 mm gap there now. Dust that out and I even sprayed some lube (WD40) in for good measure. Put it all back together and make sure the fan spins and is quiet when you power up your system.
Or else that is if your fan is working fine then your iC needs to be replaced and it is best left to a technician and Panasonic is the only supplier that I know has the part.
If you have a repair shop repair the problem, the cost could be $150.00 or more to repair.It would surely solve your problem.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 09, 2010 | Panasonic Televison & Video
I replaced the fan # 2 after getting that error on
Which fan did samsung say was fan #2 ? As from my experience dealing with Samsung they dont know the difference between the fans but fan 2 error is usually refering to the fan under the light engine in the L7 and the L6 its the small one in the gray plastic case which blows under the ballast.
Dec 09, 2009 | Samsung HL-S6188W 61" HDTV
Getting an error on my Samsung DLP model HLS5086W. Error ''check Fan No 2'' Two qustions: I can't find any information on this error online or in the manual. I want to know where to check it and how to...
If you have removed the back of the set, or if you do, you will see that all of the fans hook to the digital processor module right in the middle of the set towards the back. There will be the fan connections on the right hand side. Follow the connections of the second connector down (this will be fan #2) to the fan, and that is the one that is causing the error. Note that the fans are a three wire hook up and you will need to replace them with a simmilar fan. You may want to replace any fan that is noisy or is slow while you are in the set.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Oct 29, 2009 | Televison & Video
Need to open acer aspire 3620 to replace fan
I believe that the 4020 and 3620 have the same chassis. See if this helps
To the left of the battery there is an I/O cover with 2 screws, then the heat sink cover has 2 screws. There you should see the Thermal Unit (fan). It has 4 screws. Take those out and lift the unit out.
Let me know , curious to see if they are indeed the same chassis.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Acer Computers & Internet
PS2 Cooling Fan not spinning
well could just be shot fans are not suppose to last forever the best thing to do would be replace the fan, make sure that the fan is not plugged up with anything and it has free movement when spinning if it struggles any then its seized up which would have to be replaced measure the fan and take a look on ebay for a replacement fan of that size but if you search for ps2 fan replacement then chances are that it will cost alot more.
if you need help finding a replacement let me know im more then willing to help out.
good luck
Oct 03, 2008 | Sony PlayStation 2 (PS2) Console
1994 2.2L toyota camry radiator fans do not work
Hi.....
The Normal Temperature Range to the Fan Start is: A/C ON 181 F.
A/C OFF 199 F. When the Engine Reach this Temperature the Fan should start.
OK. Do this simple test.
1---- Start the engine, Desconnect the ECT Switch located on the Radiator,
See if the Fan come ON. If yes, if not go to step #2
Connect the ECT SWITCH and leave the car Running and with a Temperature gage.
See the temperature, if the Temperature go more than 199 F.
Turn the Engine OFF.
Disconnect the ECT sensor and check for Ground at the WHITE/BLACK wire.
If ground exist, Replace the ECT switch.
But if not. Check the wire for any damaged, and the ground at the Front Left Fender.
Repair as need.
2---- check the Fuse link RDI FAN . 30 amp.
Check the Fuse link CDS FAN 30 amp.
Replace if need.
And Return to step # 1.
Check the Radiator fan Relay, Rad fan relay 2 and 3. Replace if need.
Ok. I hope this help on your question.
I can give to you the WIRING DIAGRAM of the Fans, But I need a E-MAIL adress to do that.
Thank you for use fixya....
Sep 25, 2008 | 1994 Toyota Camry
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
