Question about Acer Aspire 5535-5050 Notebook
My acer aspire 5535 shows not connected to network, red cross over monitors, i try to connect to a network but nothing just the spinning circle, on screen I have an internet page showing connecting that the cursor will not close it just sticks, it closes down and restarts etc but im not able to do anything. Help
  • alanepreece Jul 17, 2010
    HI thanks for info, unfortunately when I click on device manager all that happens is a spinning cirlce and no response so I am unable to uninstall the network adapters. Can you advise how I can get them to work
  • 621 Answers
Go into device manager and uninstall your network adapters then restart the laptop. The network adapters will now reinstall themselves with default settings and hopefully now youre connected. Hope this has worked if so please vote
Posted on Jul 15, 2010
  • Scott
    Scott Jul 19, 2010
    Sounds like youve got more problems than just your network. If that was my laptop i'd be backing up whatever i needed then format and reinstall everything. Do you have the installation disk or a recovery partition?
Acer aspire x1200 powers on but doesn't connect to monitor
  • Kindly check the cable that connect between cpu and monitor.
  • Re-insert RAM
  • Input Voltage if not connected using UPS.
Thank you for asking on fixya.com
Mar 20, 2013 | Acer Aspire X1200 Desktop PC - Athlon X2...
My acer aspire one notebook is showing red cross on the network connection so i cant connect to the internet through my modem.also the red light besides the battery light on the right corner of the...
Unplug, remove battery, plug in, reboot. Is the Network Wired or Wireless? If wireless, connect a Ethernet cable, does it connect? post results. Verify the Network Adapter is enabled in Device Manager.
Jan 31, 2013 | Computers & Internet
Locating the motherboard battery for Acer Aspire 5535
i think, it is under the fan, but it is glued in something ? maybe you can remove the keyboard, and clip of that blue/white cable on the left to flash the bios ???
Jul 21, 2012 | Acer Aspire 5535-5050 Notebook
I have an acer aspire 5535, when i turn it on it boots up and the screen stay blank. I think its stuck in sleep mode. what can i do please help??? Nothing shows up on screen what so ever, its just bl
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 25, 2012 | Acer Aspire 5535-5050 Notebook
My Acer Aspire 5535 will not boot. when I press the power switch the machine will power on, the disk drive will spin up and the fan will spin for approx 5 secs then silence with blank screen. It first...
I don't think that you can still update the BIOS of a dead motherboard. But in your case, you can still try these steps if you haven't tried them yet, one might work for you.
- Take battery and ac adapter out then press the power button for atleast 15 seconds. Try to power on the laptop using the ac adapter.
- Reinsert the memory module/s (RAM) of the laptop. In some cases, the unit will not POST (power-on self test) if one of the memory modules installed in the unit is incompatible or defective. However, loose connection may also cause the issue. I suggest to swap memory modules on the slots (if you have 2 memory slots) or test them by turning on the unit with only one memory inserted. Using a good known memory module is also effective.
- If you have an external monitor, try to plug it to the unit and see if you can get an external display. This step will further isolate if you have a motherboard or LCD issue.
- Replace the motherboard or video card if you get nothing from the external monitor.
- Replace or check connections of the LCD cable, LCD inverter or LCD backlight if you get an external display. Note that these last 2 steps require technical expertise; however, if the laptop is still under warranty, then call your hardware manufacturer.
Hope this helps.
May 30, 2011 | Acer Aspire 5535-5050 Notebook
Acer model 5535 fails to start up theres no bios, no screen and few of the LED's come on
Any beeping? Sounds like a motherboard failure or memory issue. Can you test it by connecting to an external monitor
Feb 28, 2011 | Acer Aspire 5535-5050 Notebook
My aspire 5535 crystal eye webcam shows me upside
Hi, Try Reinstalling your Drivers for your cam.
Thanks
Feb 07, 2010 | Acer Aspire 5535-5050 Notebook
I disasembled my acer aspire 5535 to get a piece the broke off the head phones in the plug, now I can not get my keyboard, or mouse to work. Turns on and there the monitor turns on?
There are 2-3 very fragile, very small ribbon cables that attach both the keyboard and the touchpad to the motherboard. You likey do not have these connected, or all the way connected. Your going to hve to open it back up ad recheck these cables.
Nov 14, 2009 | Acer Aspire 5535-5050 Notebook
Acer aspire 5535 hibernation blank screen stuck
it might be your harddisk you should check it first it may not be loading your o/s or unbootable partition
Sep 08, 2009 | Acer Aspire 5535-5050 Notebook
Acer 5315 connection to internet
What version of Windows are you running on the Aspire 5315?
Mar 09, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5535-5050 Notebook Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
