Question about Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F
We received a Frigidaire model FFU17FC4AWO upright freezer through my parents estate. Can someone tell us the cubiic feet of this unit please?
  • 161 Answers
SOURCE: Old Kenmore Freezer
It is uaually coded into the model #. Usually in the middle. I can usually eyeball them. another solution is measure the outside dimensions of a refrigerator or freezer you know the size of then compare them. This will give you a rough estimate.
Posted on Jun 30, 2008
peyton32034
  • 410 Answers
SOURCE: Cu feet of Frigidaire Freezer modelffu14fc4cw1
according to your model number it is a 14 cu ft.  thx peyton
Posted on Jan 29, 2009
  • 9 Answers
SOURCE: freezer only cools to 40 degrees
check to see if there is ice built up on the inside back if there is it may have defrost problems or if part of the back has ice it may be low of freon
Posted on Apr 20, 2009
TheMazz
  • 78 Answers
SOURCE: I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Posted on Oct 13, 2009
  • 523 Answers
SOURCE: 20.3 Cu. Ft. Frost-Free Upright Freezer - White: What could be causing Frigidaire freezer to leak w...
stopped up drain,tear in gasket,not going into defrost soon enough
Posted on May 06, 2010
What size (cubic feet) is the Frigidaire Freezer Model # FFU17FC4CW0
I am going to guess that it is going to be around 17 cubic feet since that number is in the model number, at least that is how current models are labeled. Here is a link to a copy of the owners manual if you need it.
FFU17FC4CW0 FRIGIDAIRE FREEZER Manual
Here is another link to a page where I looked up the age of your unit and it will give you an idea where to look that up as well.
Appliance411 Service How old is my appliance Age finder date of... Hope this helps!
Feb 18, 2015 | Frigidaire Freezers
Cubic feet for Frigidaire Chest Freezer MFC13M4FW3
Good Morning, thank you for your question! This particular unit is a 12-13 cubic foot freezer. If you have further questions, please do not hesitate to reconnect.
Jul 20, 2013 | Frigidaire 5 cu. ft. / 142 liter Chest...
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Jan 29, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Unable to adjust temperature with control dial
YOU WILL most likely need a new thermostat for the unit. What evere tripped the breaker apparently welded the contacts on the thermostat. take the model number and the serial number and the thermostat you have here's the part and the model number for you 21 # 216788100 Control-temperature please be sure to rate this soilution after your done. Have a happy new year>
Jan 01, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Logo
143 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
