Question about Whirlpool Duet GHW9150P Front Load Washer
Did a load of laundry. door will not open. can't
Did a load of laundry. door will not open. can't get it to start either. need assistance on what to do to get load out and fix washer.
  • 5,911 Answers
This could be a momentary program glitch. In order to reset the Central Control Unit (CCU), you need to unplug the washer for AT LEAST 30 minutes. This should reset the CCU and allow you to open the washer.
If the door remains locked and still will not open following a CCU reset, the following link explains how you can use the manual release to get the door to open:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
You may want to try using a wet/dry shop vac to pull a vacuum on the drain hose to try to pull as much of the water (if any) ot of the wash tub BEFORE opening the door.
NOTE: Is your washer displaying any error codes? If so, the error codes will NOT be listed in the Owner's Manual. For a complete explanation of all the error codes, each one of these appliances comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to accurately troubleshoot this problem.
Read through the information provided and let me know if you need further assistance. I hope you find this information helpful.
Posted on Jul 14, 2010
Why do my clothes have horrible smell
Front loader? Welcome to our hell.
Seriously though - it's not that bad. You need to have a different mindset with these machines. First, throw away your old detergent. You've GOT to use the type with the HE logo on it. Really. There is a difference.
Wipe out any standing water in the gasket between the drum and door opening after the last load of the day.
Leave the door open slightly to allow air to flow around between washes.
Open the other doors for detergent, bleach, etc. between laundry days.
Don't use liquid fabric softener. Use dryer sheets instead.
Run a small, empty load with hot water and bleach ONLY. No clothes, as your last load for the days that you do laundry.
Use a product like Affresh, once or twice to rid the washer of existing smells. You can use Affresh any time the smells start coming back - and follow the suggestions above.
I hope this helps you as much as it helped me when I learned it! Good luck!
Sep 22, 2011 | Hotpoint Washing Machines
I have an LG WM2701H. It's about 2 years old. I did one load of laundry this morning, everything was fine. I started the second load, walked away and after a few minutes noticed that the washing...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 23, 2011 | LG Washing Machines
What does it mean when the machine gives an oL sign when starting the wash cycle?is it a quick fix and how much will it cost? It is a top load whirlpool cabrio washer.
Hi
Thanks for using FixYa. Error oL means overloaded and it flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. To clear this error you’ll have to open the door lid to clear display, remove excess laundry, then restart the cycle. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Can't open the door
If the door remains locked and will not open, there is a manual release you can use to open the door. The following link explains how:
Sometimes using the manual release will correct a momentary door jam problem and return the washer to normal operation.
If the door continues to lock and not open, you may also try unplugging the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes problems are experienced as a result of a momentary glitch in the operation program. Resetting the CCU can often correct most minor problems.
If you require further assistance, please post back and let me know. I hope this helps you.
Jun 09, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Cannot get washer door to open.
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Odor from the inside of our front load laundry washer
leave the door ajar between uses if possible , there is a product on the market now to assist the odors of front loaders. www.affersh.com . you MUST also use an HE detergent ( specifically designed for front loading washers)
Nov 13, 2008 | Kenmore Washing Machines
I HAVE FRONT LOADING 800F1 THE FRONT DOOR WON'T SHUT AND LOCK. ANY SUGESTIONS BRUCE
Dear publican,
Welcome to fixya.com
I'm Huuum and happy to assist you,
You said, I HAVE FRONT LOADING 800F1 THE FRONT DOOR WON'T SHUT AND LOCK. ANY SUGGESTIONS BRUCE
If the washer will not turn on due to the open and unlocked door!
Then the door mechanism and door switch that that activates the washer to start have failed.
You can do it your self if you know how or call service and they will get you on your way to clean laundry!
Cheers , Bless You Huuum
Please remember to leave a rating when your finished Thank You
Sep 23, 2008 | Hoover Washing Machines
I need help
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
Aug 26, 2007 | LG WM2077CW Laundry XL Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
81 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
