Question about Hoover HTC243 Top Load Washer
Hi there, I need to get a filter bag, as the one my HOOVER 550MA 5.5 KG top load washer has shredded. Would you please tell how can I get one. Thank you very much. Analia.
  • Hoover Master
  • 713 Answers
Hi just read your posting.Are you in Australia?If so,then Electrolux will have them.The phone number is 131350.I am sure they can help you with the part.Please reply to tell me how you got on or for more advice.
Posted on Jul 15, 2010
My hoover 550ma is not spinning
Dogs inside of spinner are worn out. Remove top of spinner and see dogs on the inside. Easy fix.
Sep 29, 2017 | Hoover Washing Machines
Hoover 550MA top loader tub starts to vibrate when spin starts and bang into the sides also touches the top.Noticed a rip in the top plastic cover of the tub. The load is balanced and not overloaded.
The top rubber gasket stops water splashing over the top, it also gives some deadening effect in spin. You need that replaced and also check the balance springs and shock absorbers. They do break, come dis-attached or fail.
Nov 29, 2016 | Hoover Washing Machines
How to clean out the machine a top load 7.5 kg load hoover
Open the lid, locate the centre washing spindle/arm then undo the cap on top of the spindle (this will either unscrew or just slip out, Pull up.) inside there you will see the lint filter, wash this out and put back.
Nov 02, 2010 | Hoover HTC243 Top Load Washer
Does the hoover 200m 4.4kg top loading washing machine have a lint filter if so where is it
Hi just read your posting.It should be in the center of the agitator.Pull the center out and there should be a lint bag attached to it.Unfortunately they do not stop much lint from getting on the clothes.Hope this helps and please reply if you need more help.
Jun 17, 2010 | Hoover HTC243 Top Load Washer
Hoover ultracare 1300 large load stopping mid cycle at a variety of different points and having to be manually stopped and started again at another point to complete the wash
Checkout your filter at the bottom of the machine, undo the bottom flap below the door, front. Plug off the wall mains socket. Be prepared for a lot of water so keep plastic bag, towels ready. Unscrew the plug you see to make water flow into bag; when all water has been disposed off, clean this filter & inside, refit carefully.
Feb 13, 2010 | Hoover UltraCare HC6 130M Front Load...
Where is the filter on a Hoover softwave AC 270 washing machine
hi there,
here are top load washing machine parts are located.on figure 127dff9.jpgyou can locate where the filter was located,may be this will help you.,hope you can solve but if still not run,feel free to log in to fixya we are here to serve you better.have a nice day,rate my solution.thanks a lot.
May 19, 2009 | Hoover HTC243 Top Load Washer
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Hoover washing machine (commodore 5.0 kg)
this is either a belt slip or a squeeling bearing ater seal, if it is not the belt then try doing a boil wash, this often resolves the problem. Regards Advisor
Jan 30, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Hoover HTC243 Top Load Washer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
