Question about Garden
Need instructions for replacing stator on 225 grasshopper
I'm pretty sure my stator is bad but when I turn my Yamaha Tt-R 225 over it just clicks but when I jump it of it wants to start but only a whining sound could I be wrong period?
stator is only for charging. if you charge battery up and try, it should be fine. stator will just cause excessive battery drain. same as alternator in a car. if you run it and unhook battery... it dies, the stator is bad. keeps running, stator is good.
the clicking is low battery sound, but need more info on whine
Feb 19, 2015 | Yamaha Motorcycles
What is the drive belt diagram for a model 616 grasshopper lawnmower
check the deck carefully it might be written on the right side
Sep 18, 2014 | Garden
Where do I find the alternator on a 1999 zero turn model 225 grasshopper lawnmower?
I will assume that you have a battery and a starter on your machine. If you do the alternator is incorporated into the starter. GOOD LUCK FRIEND.
Sep 10, 2014 | Garden
Battery losing charge
Sounds like you have defective diode rectifier. this little box when working properly allows your voltage to only go 1 way to charge the battery. if you have used a vehicle to boost the tractor you have damaged the rectifier. because a vehicle running puts out 14.8 volts lawn equipment is 12 volts only you can boost using a vehicle only if it is NOT running
Apr 04, 2014 | Garden
Grasshopper 225 owners manual
You are in Sewing Machines, not Lawn Tractors Mowers. Apologies
Jan 27, 2014 | Sewing Machines
How to test stator on a Yamaha 225 Moto 4 four wheeler with a ohmmeter
3 yellow (or white) wires. Test lead to lead. Should be continuity. Then, test each lead to ground. Should be no continuity.
Should also check for AC voltage when running, lead to lead. Should get 40+VAC when revving up engine.
Do not plug in or unplug wires from stator to regulator while running.
Nov 23, 2013 | Motorcycles
Just need a wire diagram for a woods 1250
I owned the same model, quite simple wiring. I went to the local Grasshopper Dealer and cross referenced it with the Grasshopper model 1212. (which is the same model because grasshopper made all of Wood's mowers for quite some time) I asked them politely and they printed it off for me for free and then I made a few purchases (oil filter, air filter, etc) because I didn't want to seem like a cheap skate.
Aug 27, 2009 | Garden
Garden Logo
102 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
