Question about Nintendo DS Lite Console
Unit will not power up. When i turn on the power, the screen flashes on then off imediatley. It does this on DC or AC power.
  • 88 Answers
You need a new LCD screen - supplied or repaired by www.dsdoctor.co.uk
Posted on Jul 15, 2010
Made pop noises screen flashed considerable hum then no power no sound no nothing
This model no. is known for AC power adapter problem. Pop noises, flashes of the screen is an indication of out-of-regulation condition on its power supply. If there's no LED light lit, then high chance that the fault came from the AC power adapter.
This model no. used AC power adapter with a 12 Volts output feed to the unit. You have to confirm the 12V output using the multimeter set in DC measurement.
If the 12V output voltage is not present, then you have to replaced it with new one. This model no. is already discontinued, only substitution is available online which will work also for your unit. You may inquire/call Sears hotline no. (1-888-213-5824) to confirm and order the AC Adapter.
Please let me know if the Adapter is intact to assist you further.
Please rate only if you feel I've gave you the best answer. If you have any question, please let me know.
Have a nice day!
Jdvillanueva
Oct 30, 2011 | Proscan 19LA25Q 19 in. LCD Television
Kryos mid7015 will not boot. I replaced the charger with a new one from Coby. I plugged it up let it charge and when I try to start it the screen flashes white a few times and the charge indicator light...
Welcome to FixYa!
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jun 07, 2011 | Computers & Internet
Dell latitude 810 will not power up and says low battery
if you plug in to charge your battery and its not charging replace the battery with a new one and a ac adaptor plug, just to avoid any more damage to your pc notebook, dont try to repair if you are unsure on what to do
Nov 23, 2009 | Dell Latitude D810 PC Notebook
E-5 error code
E5 code refer to fuser unit.To dfisplay both digits press the Enter.
E 52 Fusing error 1 Defective thermistor,heater lamp open,defective main or ac/dc drive board.
E 53 Fusing error 2 thermistor in shortcircuit,fusing harness shorted or ac/dc power supply board defective.
E 54 fusing error 3 main board or ac/dc board defective.
E 55 Fusing error 4 rhermistor open,defective main board or fusing lamp open.
When E5 service call condition occur for safety reasons they cannot be cleared by turn OFF/ON the power switch.After repairing the copier turn ON the main switch.Enter in the SP mode and press 97.Turn the main switch OFF wait 10 sec and turn ON.
Oct 07, 2009 | Ricoh FT5832 Copier
Screen flashes - samsung 215tw LCD monitor
walkstex, I will answer the last ? first. All LCD monitors WILL NEED to have their "cold-cathode-fluorescent-tubes" replaced!!! As long as your display had a Bright, Crisp image displayed on it before this "FLASHING" symptom occured, then you don't need new CCF tubes. Your problem seems to be occuring in the electronic ballast circuit called an INVERTER. It Takes 12-15v DC and turns it into 800-1200v ac to light up the CCF tubes. This is the same technology used in the new style curlieQ screw-in light bulbs called CFL's. Only difference is they use what is known as a CONVERTER circuit----AC to AC!!!! And the tubes hung horizontally on the rear of your LCD panel are thin and straight. So, to answer your first ? Yes, it is an issue of getting the CCF tubes to light up. (backlighting) Now, I should also mention that there could possibly be a problem with the main power supply in the monitor. It is called a "switch-mode-power-supply" (smps) that supplies DC for the digital signal processing board (typ +5v) and 12-15v for the inverter. Well, This typical type of symptom could be as simple as a thermally fractured solder joint on the power supply board or some bad Filter capacitors could also need replacing. I suggest that you search web to find out more about the things I have mentioned in the above text. Do search for things like "swollen capacitors", "Bulging Capacitors" and checkout www.badcaps.net for some pictures of typical failures. Get back to me if you want to carry this any further on your own. Bye for now. I'm louie12fix on fixya or lmistyrel @aol.com
Sep 23, 2009 | Samsung SyncMaster 215TW 21" LCD Monitor
Gps dosen't hold a charge. ac power charge, or mobil charge
Ahh, the notorious battery problem. I had (2) units that would not charge or turn on (red light just kept flashing). I opened the unit and disconnected the battery on (1) and completely removed the leaking battery on the other since I could not find replacements batteries. The units work fine now when plugged in (AC or DC adapter of course !). Still looking for a replacement battery...
Jun 06, 2009 | Nextar Q3 GPS Receiver
Computer wont turn on
big blue flash! I would say one or more of the filter capacitors just blew up! time for a new power supply. the AC goes into the unit and a surge suppressor is across the line - looks like an orange colored disk - from there it goes to a step down transformer to a multiple output secondary. on the secondary there are numerous "bridge rectifier" circuits that take the AC and change it to usable
dc. That DC is filtered with large capacitance capacitors. I have a site if I can still find it that has large wattage power supplies. I'll find it and get back to you.
Dec 15, 2007 | Antec TruePower Trio 550 (TP3550) 550-Watt...
MAGELLAN ROADMATE 700 ON THE FRITZ.
I had the same problem with myRm 700, too. Solution : connect your unit into the AC power pack . Turn it on. Then reinsert an address into the unit while plugged into the 110 volt ac wall outlet power supply. You may need to repeat this operation a few times.
Also, used mine in my 18-wheeler using a ac to dc power inverter. It seemed to work everytime. Note make sure the ac to dc inverter you by has enough dc output to feed your Gps all the juice it needs. That ac to dc inverter can be used to run other ac powererd appliances, too.
Aug 30, 2007 | Magellan RoadMate 700 GPS Receiver
Nintendo DS Lite Console Logo
101 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
