I have an ipaq hx2795. I did a hard reset & clear reset and now when I touch the windows icon at the top left of pda, it does not respond. What can be done about it.
  • 6,993 Answers
was the windows icon working before you did the hard reset? I believe the Ipad has having a software problem, that's why the windows icon is not responding, it might has hanged.
I would suggest that you redo the reset, as this might put the unit back to order.
Good luck.
Posted on Jul 14, 2010
  • ejrf Jul 15, 2010
    The hard reset you told me to do didn't work., what are all the other things I could do?
Backup battery won't charge
It must be the hp pda battery problem or the problem of your hp pda battery charger.
iPAQ hx2795
Jan 03, 2010 | HP iPAQ HX4700 Pocket PC
When I connet the Ipaq 2490, teh screen lights up
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit, screen will blank, device will now hard reset.
Oct 13, 2009 | HP iPAQ HX2490 Pocket PC
IPAQ HX2795 SYNC ISSUE
Is the time zone correct?
Mar 27, 2009 | HP iPAQ HX2795 Pocket PC
HP ipaq hx2795 lose sound
Hi there.
Browse to your Windows directory and look for BtCoreIf.dll and BtSdkCE30.dll. Rename them both (for example: "BtCoreIf.old" "BtSdkCE30.old")
then do a soft reset, it should work.
Bye
Jan 20, 2009 | HP iPAQ HX2795 Pocket PC
My PDA won't power down correctly.
that is a normal so don't worry.old model is will have a ghost on screed even you take out your battery or shut it down.It will disappear after a while.TRY IT
Dec 27, 2008 | HP iPAQ HX2795 Pocket PC
HW6515d Ipaq Sound with TomTom Sat NAv
The ipaq 6515 has a microswitch that will turn off the pda if the battery cover is removed. When you remove the cover and try to turn it on even with the external power supply plugged in, the red led will light up.
Jan 29, 2008 | HP iPAQ hw6515 Pocket PC
Ipaq rx3115
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
Jan 25, 2008 | HP iPAQ RX3115 Pocket PC
Hx2750 Touch screen
you said you tryed soft and hard resets..
Check the bootloader if it has a diagnostic function, my HTC model has many self tests build in the bootloader, so give it a try on yours.
Boot Loader Hold down the left, second from left and second from right buttons whilst pressing reset button
waiting for your reply.
Dec 23, 2007 | HP iPAQ H1940 Pocket PC
Hard Reset
On the front pannel you have the 4 buttons and the central navigation key. Press simultaneous the first and the last of this buttons (1 and 4) and then with your stylus (while keeping these buttons pushed) press the soft reset button (bottom of the device, a small hole). Keep these pressed alltogether for 4-5 sec then release them and do a soft reset. Your PDA should now be in factory settings. If not, try again. It will work.
Feb 19, 2007 | HP iPAQ RZ1715 Pocket PC
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
