Question about Goodman CLJ42AR49 Air Conditioner
I have a 2.5 ton ac by goodman gsx130301ba and it not cooling my house
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
My AC unit model is CPLE60-1. It is running, blowing cool air but not cooling house. Any Suggestions? and what is the life expectancy of this unit?
Your Goodman unit is a five ton and should last 15 to 10 years with proper maintenance. Parts do wear out though during the normal life of piece of equipment.
Cooling problem may be due to low charge, broken ducting, or other low airflow problem. Need to verify freon charge and then go from there.
Jul 27, 2011 | Goodman CKL36AR36 Air Conditioner
Goodman ac model # G8C13024AE what tonage is it
That is a 2 ton system. Look at the model number and the 24 is the giveaway. A ton is = to 12,000 btu's. 24 = 24,000 btu's whick is 2 tons of cooling.
Hope this help's!
Audie
Dec 10, 2010 | Goodman CLJ30AR32 Air Conditioner
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
AC not cooling
first off you should have a four ton unit. what is your super heat? is it pulling attic or outside air?
May 27, 2010 | Goodman CLQ36AR49 Air Conditioner
3 ton condensor and 2.5 air handler
I hate to use rules of thumb but 500sqft per ton depending on your windows and insulation. you are probably ok with a 2.5 ton however it will not work with a 3 ton outdoor unit as you have figured out. depending on how long that ac has been in you may want to replace it with a 2.5 ton due to the damage to the compressor valves because of the mis match. or if the indoor is newer and the original system may have been a 3 ton then i would replace the A/H. and be prepared to replace the outdoor if the valves are to far gone. If the trane is a new high effiency 2 and the goodman is just a 10 SEER you may be able to have a txv installed on the trane unit and a kickstart device outside. but only if its a high effiency but their again if the A/C fails you couldnt have a high effiency 3 ton you would have to drop down to 2.5,
Sep 22, 2009 | Heating & Cooling
10 ton goodman not cooling
Your problem description is quite broad. There are a variety of factors that may cause your AC to not cool your house. With that said, given your ambiguous description, I can offer you a diagnostic article that provides the most probable causes of your AC's failure to cool your house, and from there you can read it and then, step by step, rule out each possible cause listed in the article:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Of course, a low level of Freon/refrigerant may be the problem, but there may be other problem causers as well, as noted in the article---it may just be that debris is obstructing your AC as well. Read the article, and, if need be, take advantage of the link for free quotes and "pick the brain" of these technicians who offer you a free quote to discern what could be the problem.
Brad
Jun 22, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman CLJ42AR49 Air Conditioner Logo
458 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
