Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
I have a teledyne laars xe eg-175 pool heater, and cant get it to stay lit without holding the pilot button down.. Is this always caused by the thermocoupling going out? Or could it be the controller or the main valve also? Is there a way I can test the system without the thermocoupling in the loop to verify this is the problem. Where can I find a manual for this one? Thanks for the help.... ps I was unable to put in the proper model for the heater in the product box so please forgive the "lite 2" shown there. It is the xe eg-175.
    Top Expert:
  • Teledyne Laars Master
  • 8,686 Answers
Make sure all wires tight and strong pilot flame
Posted on Dec 10, 2017
  • 718 Answers
SOURCE: Where can I download an instruction manual for
You can download some information from;
http://www.manatron.net/Pdf's/JANDY%20MANUALS/heaters.pdf
This will give a parts list, applications and diagram.
Posted on Mar 27, 2009
  • 139 Answers
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Posted on Jun 21, 2009
  • 139 Answers
SOURCE: My teledyne laars pool heater will not cycle on. The pilot is lit and the valave is in the on position
check millivolt output should be 400-600.if less than that you dont have enough voltage to power valve
  • 2069 Answers
SOURCE: teledyne laars series 2 pool heater
First of all, I'm assuming that your heater has a pilot and not self ignition.You will need a jumper wire ( 16" of wire with an alligator clip on each end)attach one end to the terminal on the gas valve that the red wire from the pilot generator is connected to ( pilot gen. is the thing the pilot flame touches).
Now attach the other end of the jumper to the terminal where the wire from the connects to the knob where you set the water temp).
NOTE:
JUMPING BYPASSES ALL BUILT IN SAFETY DEVICES AND IS FOR TEST LEAVE THE JUMPER CONNECTED TO RUN THE HEATER FOR HEATING PURPOSES!!!!
Posted on May 22, 2010
  • 3 Answers
SOURCE: Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Posted on May 29, 2010
Pilot stays lit, burner comes on but only a portion of the burner area has flames.
remove burn tray clean out all burners sounds like all sooted up then check gas pressure to see if adequate gas pressure
Sep 13, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
How to light teledyne laars 1 series pool/spa heater
turn on gas turn to pilot then hold down button light underneath where the small silver tube goes from the gas valve hold down lite then hold for a minute then turn to on should stay lit if not need new pilot generator
Jan 28, 2012 | Teledyne Laars Pool & Spa
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
The heat wont turn on and pilot does not stay lit
If this is a M/V heater you must have at least 400mv/dc to hold the pilot valve open. Check to make sure that the pilot is lighting, then hold the pilot valve down for about a minute. If the the pilot goes out you need to see what the m/v reading is. Chances are you have a bad pilot or gen. Replace.
Mar 06, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
We have a teledyne gas furnace whose pilot won't stay lit. Any ideas?
Is this a standing pilot,or pilot always on.
If so a bad thermocouple will cause pilot to go out.
Thermocouple is a small copper tube running from the pilot light area to the gas valve. easy to replace.
Jan 14, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light wont stay lit
If this is a new item then you will need to let the gas run alittle bit longer. If this is a used item then it sounds like you are going to need to replace the flame sensor. You may have to even do it on the new item. But usually for the first start you willl need to hold the pilot down for about 1 minute to really let things heat up in there then when you release all will work
May 21, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
467 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
