Question about GE JVM1440 Microwave Oven
My microwave is making a humming noise but not heating. replaced, capacitor, diode, checked all switches including thermal switches and the wires look good going to the transformer and magnitron. Please help. Don't want to put much more money into it.
    President:
  • 670 Answers
The part that you did not replace is the problem with the oven, the magnetron. It typically fails and shorts out, causing the oven to make a loud humming noise. Not worth fixing since the cost of the magnetron is typically as much as a new oven. Sorry that you spent your time an money replacing the wrong parts.
Posted on Jul 14, 2010
Maytag MMV4205AAB Making a loud noise once turned on, and not heating food
Investigate these three areas if your microwave won't heat food and you hear a loud buzzing or humming noise.
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
I hope the above is helpful.
Regards.
Walesarumi
Sep 27, 2011 | Maytag MMV4205 Microwave Oven
Tip
What to do if your microwave oven does not heat and you hear a loud buzzing or...
Hello,<br /><br />Investigate these three areas if your microwave won't heat and you hear a loud buzzing or humming noise:<br /><br />Power Diode<br /><br />A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.<br /><br />Testing a diode<br /><br />NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.<br /><br />Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.<br /><br />A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.<br /><br />With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.<br /><br />A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.<br /><br />Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.<br /><br />High Voltage Capacitor<br /><br />A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.<br /><br />Magnetron<br /><br />A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.<br /><br />Testing a magnetron<br /><br />NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.<br /><br />There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:<br /><br />TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.<br /><br />TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.<br /><br />Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.<br /><br />http://<a href="http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor">www.fixya.com/support/r7088355-replace_microwave_ovens_diode</a><br /><br />http://<a href="http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor">www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor</a><br /><br />I hope the above is helpful.<br />
on Dec 02, 2010 | Microwave Ovens
Tip
Micorwave ovens - and where's the heat?
A microwave not heating up is caused by one or more of the following -
1) Failed controller board (unlikely if you are getting a clock readout and you can get the various functions to work, just no heat)
2) Failed door switch
3) Failed thermal fuse, when used
4) Blown power fuse that is dedicated to the microwave circuit
5) Bad diode
6) Bad capacitor
7) Bad magnetron
8) Bad transformer
Door switches insure the microwave circuit will not engage when the door is open. Slamming the door of the microwave is hard on the switch.
The thermal due is wired into the microwave harness, and is a melting allow type, based on heat buildup within the oven. Always replace with a fuse of the same thermal rating.
The power fuse is a special type and should only be replaced with that same type and rating. It is easily tested.
The diode is a relatively inexpensive part, and is not easily tested. If a grumble is heard coming from electrical area of the unit, then the diode could be shorted.
A shorted capacitor will blow the fuse immediately. And open capacitor will cause a "no heat" condition.
A bad magnetron will also cause a low level hum or grumble from the transformer. But is may also cause no other identifiable symptom of failure.
A bad transformer will exhibit a grumble or hum, and may or may not blow the fuse. But be careful here, the secondary of the transformer produces very high voltages, up to 2.5Kv. Few people own a meter capable of measuring such voltages.
Service and repair of microwave ovens is dangerous work. If you don't know what your doing, DO NOT ATTEMPT TO SERVICE A UNIT WITHOUT INSTRUCTION.
on Feb 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
It is making a funny noise plus has an electrical burning smell and won't heat.
The funny noise is usually called a humming sound. When the microwave begins to bring out this type of sound, it refuses to heat. Below is troubleshooting tip and a fix;
Investigate these three areas if your microwave won't heat and you hear a noise....
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Apr 10, 2011 | GE Microwave Ovens
Oven has loud hum but will no longer heat food.LRM1260SW Purchased Oct. 09
Investigate these three areas if your microwave won't heat and you hear a loud humming noise/sound.
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Apr 08, 2011 | LG Microwave Ovens
It just started making a louder humming noise and now it doesnt heat up anything at all? any suggestions?
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Take care.
Feb 15, 2011 | GE JVM1850 1000 Watts Microwave Oven
Makes a humming noise wont heat
If its making a humming noise, that means the diode is bad and should be replaced. Once replaced the microwave will begin to heat again.
Feb 11, 2011 | Kenmore 62622 Microwave Oven
Turns on but no heat. ? is there a fuse we can replace and where is it?
5) Bad diode
6) Bad capacitor
7) Bad magnetron
8) Bad transformer
Jan 16, 2011 | GE JVM3670 Microwave Oven
Microwave won't heat, light ,clock works the microwave just won't heat the items in it.
hELLO THERE
when a microwave quits heating but every thing else is ok normally
investigate these 4 areas
Investigate these three areas if your microwave won't heat but you hear a loud buzzing or humming noise:
microwave_diode.jpg Power Diode
picturena.gif High Voltage Capacitor
microwave_magnetron.jpg Magnetron
Nov 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
Oct 27, 2008 | KitchenAid KHMS145KSS Microwave Oven
GE JVM1440 Microwave Oven Logo
398 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
