Question about DekCell EasyCap USB 20 Video Capture Adapter with Video Editor Software (CPA1280) Video Capture
When trying to load the info from the cd it wont accept it. Well its now a paper weight. What do I do???
    Guru:
  • 158 Answers
Hi,Not sure if your useing windows 7 but I have posted some directions give it a try hope it helps.
One other thing try installing the software as an administrator.Open my computer right click the drive that has the CD in it and in the drop down click run as administrator.Here's the link to some directions http://www.fixya.com/support/r4954235-windows7_64bit_easycap_directions If you have the Easycap Usb pluged into the computer now unplug it and reboot befor trying the install directions,good luck......
Posted on Jul 16, 2010
Denon 700 wont accept cds
The CD loading mechanism has the fault. Check its loading belt. If it is OK, replace the loading mechanism.
Jun 03, 2012 | Audio Players & Recorders
I have a stupid question where the heck do Iload the paper in my Lexmark X2350 printer??
Facing towards front of the printer, on the back of it you have raiser - paper support panel, with side slider on the left hand, push slider towards left in full.
Paper accepted by this printer is all standard grades, like A4, L4 and fall in these dimensions:
width min/max - 76mm to 216mm (3" to 8.5")
lenght min/max - 127mm to 432mm (5" to 17")
Printer will accept paper weight between 60g and 180g, that meant that all standard weight of paper including cardstock will be accepted, printer as well will print photo and envelopes.
• The paper is loaded against the right side of the paper support.
• The paper guide rests against the left edge of the paper.
1. Put paper long way vertical on raiser (paper support), about 80 to 100 pages of standard paper will fit there (depends on thisckness),
2. Push paper against right side
3. Adjust width with left hand slider. Do not buckle the paper!
After print paper is ejected at front bottom slot, printer side up. if you use photpaper or gloss paper, remove it immediatelly as need longer drying time and will get smudget by next printsheet.
You can find information with pictures in your manual on page 13/14.
Hope this will help you print beautiful pictures!
Aug 11, 2010 | Lexmark Z2300 InkJet Printer
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP Photosmart C5180 (wont accept photo paper but will normal paper)
Load the printer with the slick glossy paper face down. See if it will print.
Jun 06, 2017 | HP Photosmart C5180 All-In-One InkJet...
Paper is not feeding through. Keeping getting message that "load paper". But when loaded paper is not being picked up. The meachine is only 2 years old. Olready the roller has been changed. Please advise...
The paper’s weight may be expressed on a different basis than the paper used to rate the printer’s capabilities. For example, a 20-pound bond paper equates to 28 pounds cover and 42 pounds index papers in thickness. The differences among bases stem from the sizes of the large sheets from which the paper was cut. For example, Sharp says, bond paper’s weight is determined by 500 sheets of 17- x 22-inch stock (later sectioned into 8.5- x 11-inch reams), whereas index paper’s weight stems from 500 sheets of 25.5- x 30.5-inch paper.
Match the basis for the weight of the paper to the basis of the printer’s maximum paper weight rating. If the printer was rated on only one basis, such as cover or index, and your paper ****’s wrapper only lists the paper’s weight by another basis, such as bond,
Mar 17, 2008 | Canon PIXMA MP780 All-In-One InkJet...
CD WONT PLAY
It sounds like it is attempting to read the t.o.c. (table of contents) which tell the unit where everything is on the cd,and failing to do so, then ejecting, the first thing to do is try cleaning the lens and if there is no change then replace the laser pickup
Nov 21, 2007 | Car Audio & Video
Printing on heavy cardstock
HP recommends papers with ratings of at least 90 for brightness and 75 g/m2 (20 pound) weight. before u proceed....remove the rear access door to reveal the rollers.Take a slightly wet cotton cloth and wipe the rollers in the upward direction 4 times.Close the rear access door. now do as said - START -PRINTERS & FAXES -CHOOSE THE PRINTER ICON THAT HAS BEEN HIGHLIGHTED WITH A CORRECT MARK. - RIGHT CLICK - PRINTING PREFERANCES - PAPER/QUALITY TAB - CUSTOM -Create a new custom paper size that is dependable on the paper you are using - type a name & SAVE -ok -ok -try printing if the problem still insists the report back and do mention which tool you are using for the printout. if its heavy pearlized paper then i do not think th eprinter would accept it . it maintains its own standard weight to detect the paper.
Sep 23, 2007 | HP Photosmart 3310 Printer
CD WONT PLAY
guessing that your laser diode or drive motor or laser sled has stopped working...need more info...
Jun 01, 2007 | JVC AM FM CD DET FACE CAR STEREO
Samsung CLP 550N paper jams
Make sure the paper guides are not too tight and always fan the paper to rid static build-up before loading.
Jan 19, 2006 | Samsung CLP-550N Laser Printer
DekCell EasyCap USB 20 Video Capture Adapter with Video Editor Software (CPA1280) Video Capture Logo
115 people viewed this question
Top DekCell Televison & Video Experts
Robin Hill
Robin Hill
ka4iup
ka4iup
Clif Roberts
Are you a DekCell Televison and Video Expert? Answer questions, earn points and help others
