Question about Miele Optima G2430SCi Stainless Steel Built-in Dishwasher
Silverware on top rack is not getting cleaned
    Genius:
  • 1,075 Answers
Top spray arm clogged remove and clean.adrian,,,,,
Posted on Jul 15, 2010
Door will not shut when upper silverware holder is in
Make sure you are installing that silverware holder properly. The little tabs of the silverware holder are supposd to go over and around the mating bars of the upper rack. Barring that, your upper rack may be pulled (bent) out, and you may have to push it (hard) to get it back in shape.
Oct 30, 2014 | General Electric Adora GHDA670N Built-in...
My dishwasher isn't washing the dishes on the bottom rack? The silverware is clean and the top rack ins clean..
make sure the lower spray arm is free from objects in the ports and spins freely. If you still have a problem LG is offering some customers an pump upgrade free of charge depending on the age of you dishwasher
Sep 01, 2011 | LG LDF6920ST Stainless Steel 24 in....
The top rack and silverware do not look clean even with high heat water and pots and pans setting
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
The other thing is to check is that you have added salt (dishwasher salt not cooking) in the water softener and that the machine is set for the water hardness in your area.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Whirlpool 24 in. GU2500 XTP Built-in...
Glasses int he top rack of my kitchenaid dishwasher don;t get clean. they finish the run spotted and covered in what looks like baked on dirty dishwater. dishes in the lower rack look ok, but the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 11, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a whirlpool quiet partner II dishwasher. There is a gritty residue on the dishes in the top rack and on some of the silverware. Any suggestions on how to fix this?
MAKE SURE THE UPPER WASHER ARM IS NOT CLOGGED, SOMETIMES FROM DETERGENT BUILD UP IF YOU'RE USING POWDER DETERGENT. CHECK ALSO FROM THE BOTTOM IS THERE'S ANY DEBRIS THAT MAY PREVENT THE WATER GETTING TO THE UPPER WASHER ARM
Jan 16, 2010 | Whirlpool Dishwashers
Odor in dishwasher, not cleaning silverware, dissapointed
Most dishwashers have a strange smell, forever. It's the nature of the beast. A drying agent is required for dishwashers, even when using the drying cycle. Silverware is difficult to get clean, if it isn't prewashed, like everything else. A liquid dishwasher detergent along with turning your hot water temperature up a few degrees will help matters.
Don't overload it and the dishes will come out a lot better.
Sep 05, 2009 | Bosch Evolution 800 SHE68M0 Built-in...
Whirlpool Gold dishwasher
Either:
  1. not enough water gets into the dishwasher. check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Mar 21, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Silverware container
If we are talking about the quiet partner 3 the silverware container can actual hang more effectively on the lower dish rack itself as opposed to on the door. The flap also does just snap on. Hold the back side of the metal with your thumb while pusing with even pressure on the plastic flap. I still reccomend though hanging the whole assembly on the outside of the lower rack.
Jan 10, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher not cleaning
make sure the screen is clear and not obstructed,also check the wash arms for the same.does the pump sound any different?are you getting enough water in it.when you start a cycle open it up and make sure there is plenty of water,do this a couple of times so you can get a good idea of what should be in there.the drain solenoid may have failed and your losing water.
Oct 28, 2007 | Dishwashers
Miele Optima G2430SCi Stainless Steel Built-in Dishwasher Logo
121 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
