Question about Apple Computers & Internet
I need to know how to correctly install the PRAM battery Imac
I replaced the PRAM battery on my Imac and it hasn't worked since. It will boot from a CD but not from the hardrive. I've reinstalled the OS but that didn't help.I booted in single user mode and it said it can't load a particular driver. I tried again and it had a kernel panic.It will still boot from a n Install Cd but not from the hardrive.
  • Steve Caulfield Jul 14, 2010
    Does anyone know how to correctly install a PRAM battery on the motherboard? That's all i need to know-I have already been thru everything else (resetting PRAM,reinstalling the OS,and single user boot.
  • Steve Caulfield Jul 15, 2010
    Yes- if it doesn't I most likely have the battery in backwards.
    Top Expert:
  • Apple Master
  • 83,772 Answers
ARE U SURE U INSTALLED THE BATTERY CORRECTLY?
Posted on Jul 14, 2010
    That's what I'm trying to find out-I'm not sure-or I wouldn't have asked the #$%^& question!
  • Marvin
    Marvin Jul 15, 2010
    I assume u switched the polarity of the battery, each side or terminal is marked with a plus or minus, just reverse the polarity of the battery and see if the system comes up
    President:
  • 1,561 Answers
I advice you follow the below procedure,
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys. This should fix the problem and correct all the abnormalities.
Take care.
  • 2 more comments
    I have already done that and it doen't work.
    I have alread tried all the solutions except getting a restore disc for Tiger 4.
  • Sulaimon Jimoh Olayemi Jul 15, 2010
    Is this the procedure you followed while replacing the PRAM on your imac?
    Changing out a battery is not
    difficult on most Mac systems. Simply pry off the retainer and pull the
    battery out. Reverse the procedure with the new battery making sure the +
    is positioned correctly.
    Restart your system and reset the date
    and time and other control panel settings as needed.
    Note for the
    4.5V Batteries, they are small square and black. They are stuck down
    with velcro. Simply pull up the old battery and unhook the cable.
    Reverse the procedure. There is only one way the cable plugs back in.
    Once
    you've replaced the battery, you will want to reset several settings.
    If you're on a network, you'll want to open the Chooser and enable
    AppleTalk. Note some Macs may not support all these control panels
    (preferences in OSX). These are the control panels you'll need to use:
    Startup
    Disk. Always reset your startup disk. Your system may not boot well or
    give you the flashing question mark if it gets confused.
    Date
    & Time. First, choose your time zone, then set the date and time.
    Memory - Mac OS 8.5 and later will usually set this automatically. Set
    your cache to a Meg if you have plenty and 1 meg over on virtual.
    Network
    or AppleTalk. If you're on a network that isn't LocalTalk, you will
    need to reset your network connection on any Mac with a LocalTalk port.
    Mouse and Keyboard.
    You'll need to reset the mouse tracking and
    double-click speeds, as well as setting the keyboard delay and repeat.
    Energy
    Saver or Auto On/Off. Energy saving settings, power-up time, etc. are
    stored in PRAM and need to be reset.
    Monitors and Sound or
    Monitors & Sound. You need to reset speaker volume and monitor
    bit-depth and possibly resolution.
    Take care.
    The problem is that I didn't pay attention to the polarity of the battery when I took it out and I don't know if I put it back in correctly. This is a 3.6 volt lithium battery but it is not a coin battery. It is a 1/2 AA battery which is shaped like an AA battery. I can find manuals for Intel based G3 400 DV imacs but this imac is IBM based and is different in construction.. The motherboard has a + sign on it near the battery but I don't know if it relates to the battery's polarity.
Which part is failed on my iMac with white screen?
Did you read the Apple support page on this problem? they are really good in helping: Troubleshooting My computer won turn on
Nov 25, 2014 | Apple Imac Alum. 20" 2.4ghz Intel Core 2...
My imac does not start white screen with a ? mark
reset pram,
try holding down s key to boot in safe mode,
try holding down option key on startup and select drive,
install system disk and restart holding down c key.
Feb 09, 2014 | Apple iMac G4 Desktop
Imac intel dual core dvd drive will not mountunable to load a cd or dvd it keep ejecting them. I have tried to boot with the OSX CD, but still it eject it out. I notice the problem when I tried to...
Installing Parallels should not change the way your optical drive works.
Try resetting the SMC as per the following article:
http://support.apple.com/kb/HT3964
If that doesn't work, try resetting the PRAM:
http://support.apple.com/kb/ht1379
If these do not resolve the issue you will likely need repair.
Jun 20, 2010 | Apple iMac Z0CY Desktop
I have a iMac G5 powerPC which is not booting up. Investiagtion online has shown that the PRAM needs to be reset. However when I change the RAM configuration and press and hold command-option-p-r, it is...
You must remove the back panel and press the pushbutton on the motherboard by the 3 leds. If that does not work then you may have the dreaded power supply or capacitor failure. Search the web and youll understand. There are some fix it web sites but if you still have applcare take it in to a apple store and they may repair or even replace the unit.
Apr 15, 2010 | Apple iMac G5 Desktop
Imac g4 lcd black screen replaced pram battery
If you can find an older SVGA monitor, try hooking it up to the port on the back of your mac. If you get video then chances are the LCD display is shot.
Sep 01, 2009 | Apple iMac G4 Desktop
IMac 10.4.11 all of a sudden only boots in safe mode
try resetting the SMC and the NVRAM. This occasionally stores the startup state and any keystrokes used during boot. Common issue with all intel macs. Resetting PRAM and NVRAM 1. Shut down the computer. 2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4. 3. Turn on the computer. 4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears. 5. Hold the keys down until the computer restarts and you hear the startup sound for the second time. 6. Release the keys. Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models. To reset the SMC on an iMac 1. From the Apple menu, choose Shut Down (or if the computer is not responding, hold the power button for approximately ten seconds until it powers off). 2. Unplug all cables from the computer, including the power cord. 3. Wait at least 15 seconds. The SMC reset occurs automatically once the iMac has been unplugged from the AC power source for several seconds. 4. Plug the power cord back in, making sure the power button is not being pressed at the time. 5. Reconnect your keyboard and mouse to the computer. 6. Press the power button on the back to start up your computer. Note: The iMac does not have a button on the main logic board for resetting the SMC, which eliminates the need to remove the computer?s cover to reset it (as required for some other models).
If you need further help, reach me via phone at https://www.6ya.com/expert/jarrad_11786570be7a2abd
Jun 10, 2009 | Apple Mac OS X 10.4
IMac Intel wont boot
It sounds like you need a new motherboard.
May 06, 2009 | Apple iMac G5 Desktop
Booting an iMac g5 for the first time with out the system disc.
There are several reasons why you could be having this problem. You first need to know a little about the various "flavors" of Apple computers and operating systems.
There are two brands of processors: PowerPC (this is what you have) and Intel (what Apple switched to after your model).
There are also different types of system install disks: Specific Version (this is what would have came with the iMac originally and contains only the drivers for that model). Retail Version contains drivers and "Universal" processor code for all of the supported models and both types of processors.
Intel Macs format their drives differently than PowerPC macs. So, if the used drive was formatted for Intel you wouldn't be able to mount it, if the install disk that was used was Specific Model type rather than Retail type when the system was installed on your used disk, you wouldn't be able to mount it either.
The drive you have must be formatted for PowerPC and system installed from either the Specific Version or Retail install disc in order for you to mount it.
Jan 22, 2009 | Apple iMac G5 Desktop
Computers & Internet Logo
35 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
