Question about Microsoft Computers & Internet
Windows 7 is shutting down my graphics card (Nvidea) ...error 43...and freezing screen resolution at 600x480. Tried updating the driver, restoring the system to an earlier point, tried reboot at last known good configuration...system restore works for about 5 minutes than windows shuts the device down again. Any suggestions?
  • 22 Answers
Press "F8" before Windows boot and you'll be presented with Advanced Boot Option. Select Safe Mode and hope it can booted successfully into this mode. Uninstall the related driver and reboot the system to normal mode.
Once it is booted, install the driver obtained from NVIDIA which is WHQL certified for Windows 7. Once installed, reboot your system and hope it works now.
Posted on Jul 15, 2010
I am using VA1903wm LCD monitor from Viewsonic. It worked well at its non standard resolution of 1440*900 when used with Windows Vista. i had to upgrade to Windows 7 Enterprise edition and this resolution...
Update your graphics card drivers to the newest ones available. That is typically caused by having the default windows driver for your graphics card. If it is a Nvidia gpu get the drivers from them, itf its an ATI/AMD get them from AMD Game. If it is neither of those Intel does some graphic cards, if its not an Intel one go to the computer manufacturers website and find your model to get drivers for it.
May 17, 2011 | ViewSonic VA1930WM LCD Monitor
When i start my fifa 11 then it can't start its writting E0001,what shoul i do?
Lol just change your resolution and then change back....worked for me
Dec 10, 2010 | Computers & Internet
Resolution issues since vista upgrade
Just force and install the driver, It should be working good. I too had similar problem. I just forced and installed the driver even though it said that its not compatible.
Nov 12, 2009 | Microsoft Windows Vista Home Premium with...
Resolution problem in Windows 7
Windows 7 official release is in Oct. The Windows 7 version you have is probably the Release Candidate version, this is the last Beta version before its offical release. This version does not have drivers for al lot of devices and if you cannot get the driver from ATI at this stage then you have to wait until it becomes available.
The release Candidate will shut down every hour early next year and will stop working completely in June. You will be forced to buy Windows 7 or go back to XP or Vista.
Sep 20, 2009 | Computers & Internet
Error code 43
When going from the onboard Video  to the Video card, on all the most computer I have seen,, you need to go into the BIOS setup screen and turn off the onboard graphics to avoid a software conflect, which it appears that you are having..
Jan 21, 2009 | Computers & Internet
Error code 43
Uninstall both video cards, disable the integrated card in the bios, and then reinstall the stand alone video card. If you continue to have problems, please post what motherboard you use and what error code device manager gives.
Jan 14, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Computer Crashes -- error msg is that GEForce 4 (4000) is causing my crash
It may not be video card it could be system files at fault I had similar and some files were not indexed
go to C:\ right click Properties / Tools error check check errors new box opens tick the small square to fix errors and reboot while rebooting windows will scan disk and fix errors and if you are quick enough will see what it fixed then it will restart
I scan disk to fix errors every 3/ 4 weeks and do not have may problems
Aug 13, 2008 | Nvidia GeFORCE 4 MX440SE / 4000 / 4X DDR...
Acer al2016w monitor
when you say you have it plugged into the on-board video output.. does that mean there is a graphics card installed too? used to be graphics card installed? if there is or was then its possible that there is a bois setting that tells your computer to use the existent or non-existent graphics card. either was your onboard is going to shut down. This is one theory.. but since its is turning off once you get to your desk top the more likely reason is that its software based and you either have the wrong resolution, driver, or refresh rate selected to use when windows boots. Toy around with diffrent resolutions, refresh rates, also if you have a graphics card plug it into that. your on board most certinly will not be enabled if you have a graphics card.
VGA MODE in vista:
Restart the computer and immediately start pressing the F8 key, once per second. At the selection screen, use the up/down keys to select "Enable VGA Mode", then press the "Enter" key.. If it works, it will bring up the basic VGA drivers in "normal" Windows and should allow you to install the Vista compatible drivers for your new card. After installing the new drivers, restart the computer and if it remains in VGA, you should then be able to adjust the resolution, etc. from the "Display Properties".
Jan 22, 2008 | Acer AL2016W 20" LCD Monitor
Error code 43
What you have to do, with your monitor still plugged into the onboard, is disable the onboard controller then restart.
Your screen will go to 640x480 during this process, but no worries.
Once you've logged back in to vista, open up your device manager again to make sure that your card is now enabled. If not, enable it. Also make sure that your cards' driver sortware is updated.
Switch your monitor over to the card now. No need to power down.
Open display properties, set your dual monitor setup to default on the single monitor that you do have plugged in and reset your screen resolution... and maybe even upgrade your monitor driver from generic to specific if you want.
The issue with nvidia cards isn't with vista or nvidia at all. It's a simple matter of driver conflict between the card and the onboard chip. You just have to tell vista that you'd like to make the card the priority adapter by disabling the onboard.
However, disabling the onboard DOES NOT make it unavalable to you. You can still utilize it in a dual monitor setup as a generic adapter without conflict.
Dec 26, 2007 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
