Question about Watches
I'm using Nike Zero Drift. A old model with altimeter and compass. Just change a new battery and all functions are working but the led continue to flash/blink. what is the problem and how to fix it?
3 Suggested Answers
escapement
  • 2338 Answers
SOURCE: the screen is swithing between compass - baro -
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
Posted on Feb 27, 2010
Sebin
  • 712 Answers
SOURCE: i want to reset the
Which is your watch model?
Posted on Sep 12, 2010
The altimeter on my Timex Helix reads LO and can't be changed. I changed the battery -- anything else I can try?
Timex Helix ABT.
This watch calculates altitude by measuring air pressure and relating that value to the international standard atmosphere. 1013.25 mb = 0 metres.
The Timex ABT does not display negative altitude values. So if the measured air pressure is greater than 1013.25 mb and the altimeter is reset (select altimeter, pull out the crown 1 click and press and hold the lower left button) the watch will display LO. You can experiment with this. Wait till the barometer reads 1013 or 1012 and reset the altimeter. The watch will display zero or maybe 5 metres. Or wait till the pressure goes up to, say, 1022 and reset the altimeter. The watch will read LO again. If this happens alot, you probably live fairly close to sea level. What you can do to trick the watch is use a vacuum cleaner to raise the perceived altitude of the watch then calibrate the altimeter (pull out and rotate the crown) and change the altimeter reading to, say, 200 metres. It wont read LO then. Keep an eye on it and the atmospheric pressure. If the pressure starts to rise then adjust the altimeter accordingly. Remember this watch is designed to measure proper altitudes where the air pressure isnt likely to be as high as 1013.25. If you are mooching around near sea level the naturally changing air pressure will often make the watch read LO.
If you live up in Montana at 1500 metres (ISA standard pressure about 840 mb) all the time then the watch will always read a positive value and you can calibrate it from reference to a map or road sign etc. The atmospheric pressure will unlikely reach as high as 1013 up there and the watch wont read LO.
Feb 01, 2014 | Timex Watches
Need shell/bezel
Either send to Casio or get new watch. I go with the latter
Sep 22, 2012 | Casio Pathfinder PAG40B-2V wristwatch
Touch screen is not working for several functions on tissot t-touch: notably started with altimeter, then meteo, now alarm.
==== http://www.voguecatch.com ==== ====accept credit card and paypal
Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag......welcome to ==== http://www.voguecatch.com ====
Nike shox(R4,NZ,OZ,TL1,TL2,TL3) $35
Handbags(Coach lv fendi d&g) $35
Tshirts (Polo ,ed hardy,lacoste) $13
Jean(True Religion,ed hardy,coogi) $30
Sunglasses(Oakey,coach,gucci,Armaini) $15
New era cap $16
Bikini (Ed hardy,polo) $18
Oct 23, 2010 | Tissot T-Touch T33159851 Wrist Watch
Touch function is not working
I had the same issue. After installing the battery and trying to calibrate several times... to no avail.I tried pressing the T button, keeping it pressed down and then install the battery. It give you a mode or function setting ( I'm not sure what it means). i then press the T button and it cycles through these mode setting. I synchronized the hands and then was able to get the: altimeter, compass, meteo, date and time working. The temp, chrono still doesn't work.
I think getting all the functions to work, depends on the mode setting... but i don't know the correct setting.
Jun 30, 2010 | Tissot T-Touch T33759851
Adventure tech doesn't have chime
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: info@goamfix.com
web: www.goamfix.com
Sep 14, 2009 | Timex Expedition Adventure Tech Compass...
Tissot T-Touch Baro way too high
Try to recalibrate the Baro/Altimeter as below:
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the watch. This will also calibrate the Meteo.
To calibrate the Altimeter:
1. Activate Crystal
2. Press Altimeter
3. Press and hold top + button until the watch beeps and display flashes.
4. Use + and – buttons to adjust altitude
5. Press center of dial to lock in.
Aug 05, 2008 | Tissot T-Touch T33159851 Wrist Watch
Casio Protrek PRG-70-YT
wait until the battery is full reloaded
Jul 08, 2008 | Casio PRG-40T-7 Pathfinder
Casio Altimeter watch, no instructions
I was just gifted an old casio pathfinder model 1675 with the manual.
when inserting a new battery.....step #4
AC (AC CLEAR) touch the AC contact and the battery +(positive) side with metal tweezers for about two seconds.
Contacting the AC (all clear)is necessary when a new battery is installed to clear the previous memory to avoid erratic display..
I am going to get a new battery for it soon I want to play with it....and figure out how navigate through the functions.
oh yah......the pictures are extremly small but the AC contact point is apparently marked? inside the case obviously next to the battery close enough for the needle nose tweezers to reach each contact. I havent unscrewed my case yet, I want to have everything I need at hand like the battery before I dive into this thing. I dont mean to dumb it down, I was trying to keep it simple as the manual is 55 pages and a little confusing. I hope this helps the battery problem. I will try to delve into the reset problem from the other post..each function appears to have a reset option ......maybe crack the case open and try the new battery all clear thing with tweezers...maybe this would reboot so to speak the entire watch , being mine does not work and have only had it in hand for two hours I am pretty clueless, I was looking for how much the watch costs...i didnt relize it was a fairly old model, the new ones with the compass look very cool. anyhow goodluck
Oct 21, 2007 | Casio W752V3AV men's watch
Nike triax speed WR0082 regular
You must Re-Link the SDM pod to the watch after changing the battery. Go to the link below, It's not the exact model, but, should work, if not, go to www.nike.com and download the manual for your model.
GOOD LUCK
http://www.nike.com/timing/extranet/product/triax_elite/elite_manual_eng.pdf
Aug 25, 2007 | Nike Triax Speed WR0085 wristwatch
"Tissot Touch" Touch screen failure
it all stems from the watch not actually being waterproof it's more water resistant than waterproof. The little indentations on the back that look like they are for a tool to unscrew it are actually holes i guess for the altimeter and meteo so it can sense pressure. Behind the back just behind the holes is a nylon gauze material and underneath this is a sensor slightly recessed and covered with some kind of waterproof substance. As far as i can see the problems lie here any water sweat or other foreign object than gets into this gauze will eventually will clog this gauze material which at first will affect the altimeter then the meteo. When the gauze has been clogged up severely i gets very dirty indeed which means when it gets wet it takes an age to dry out so if you wear it in the shower like i used to it will never dry out this causes the watch to malfunction quite severely. You can actually fix this problem yourself just get a very small flat screwdriver and lever the back off don't worry it's only a push fit and comes of easily you will see straight away a dirty damp smelly clogged up round piece of nylon gauze clean this up with a bit of WARM not boiling soapy water being careful not to disturb the pressure sensor and it's waterproof goo inside then dry it all and put it together
Hope this helps
Dom
England
Feb 12, 2007 | Tissot T-Touch T33159851 Wrist Watch
Watches Logo
407 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
