Question about Canon EF 75-300mm Lens
How can i dismantle , 75-300 canon lens - Canon EF 75-300mm Lens
  • kakima Jul 14, 2010
    Before you start, consider the other end of the process. Do you have a lens collimator and other gear necessary to ensure you get the lens aligned so it works properly? If not, you may as well use a sledgehammer; the photographic results will be similar.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Having gone over a month without a response, I assume this is no longer a problem.
Posted on Sep 10, 2010
5 Suggested Answers
Agent Allan
  • 480 Answers
SOURCE: camera lens
Hey kgconstruct,
The lens description that your posting is categorized under is a 75-300 f/4-506 DL lens for Nikon AI. If this is correct then no this lens won't work on a Canon camera. I am assuming this isn't correct and the lens you have is for a Canon camera, and if this is true this lens should work on the XTI. If you’re thinking of buying this lens I would go to a local camera store that carries this Sigma lens and try it out first to make sure you like it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 18, 2008
  • 9 Answers
SOURCE: My Canon 4000D keeps comming up with
They where rechipping (some year ago). You can still use that lens but in AV mode. The new Canons are incompatible with the old Sigmas regarding aperture. If the machine needs to change it it will ALWAYS return a error 99. If the lens is on a bigger F stop you first need to use an old Canon (35mm) to open the aperture to the max (smaller F stop). Then you can use the lens but only in AV mode.
Posted on Jul 03, 2009
  • 13 Answers
SOURCE: which digital cameras can the sigma dl 75-300 lens...
nikon dslr cameras.ie,d70,d80.full frame and aps sensors,dl macro super lens good for post d70
Posted on May 26, 2010
elix0411
  • 3530 Answers
SOURCE: Error 99 with a Canon
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for using Fixya!
Posted on Jun 06, 2011
Ho w to dismantle canon zoom lens 85-300
Unless you know what you're doing leave it to the professionals.
Feb 22, 2015 | Canon Cameras
Dismantle a canon 50mm f1.4 ssc lens
What do you mean dismantle? Take the lens apart or remove from the body of the camera?
Jul 13, 2014 | Canon EOS 7D Digital Camera
Canon 50 mm 1.8 communication error 01 lens malfunctiion
Might be that the aperture is stuck and you need to get the lens repaired (might cost more than a new lens.) Or it might just be bad contacts. Clean the contacts and try another lens before asking Canon or dismantling the lens.
Aug 30, 2013 | Canon EF 50mm f/1.8 II Lens
Lens retraction noise in canon powershot pro 1
The lens needs to be dismantled, cleaned and lubricated by a camera specialist, the alternative is a lens that will eventually seize, shutting down the camera.
Apr 08, 2012 | Canon PowerShot Pro1 Digital Camera
Error message that lens had a problem
Usually caused by impact or sand in the lens unit - the lens needs to be dismantled and investigated.
Jun 09, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I need a new lens for my camera were can i buy it!
The changing of your lens is not something which is an easy project.
If this is a point and shoot camera, the removing of the lens requires to dismantle the camera completely. This is not a job for the timid. It also will require the lens to be aligned internally with the re-adjustment of the electronic components with a program from Canon on your computer. Some of these programs will require a purchase.
I would suggest to either have it repaired by Canon or some repairman, or sell it at a site such as Ebay for repair or parts. You may also opt to trade-up or trade-off to Canon's Refurb program. Canon info
Sep 02, 2009 | Canon Cameras
No power. Lens 'protruding'.
There are six other things to try besides shaking, tapping, and bashing listed on the following blog page. Especially try the one starting the camera with the memory card removed. Do not recommend dismantling as your chances are very slim in repairing that way:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 26, 2009 | Canon PowerShot S30 Digital Camera
Water inside the lens (Canon EF-S 17-85mm F4.5-f5.6 lens)
if it is only fogged you can blow hot air on the lens while fully zoomed in and after the water has evaporated, zoom out to compress the moist air out. do this several times.
May 23, 2009 | Canon Cameras
Lens won't close Shows error E18 Can't find the pictures to dismantle
This is a pretty common lens problem for Canon. Read this page for more detail on the error and how to resolve it:
http://www.e18error.com/repair.html
Dec 18, 2008 | Canon IXUS V2 Digital Camera
Canon A610 Lens problem
Unless you have prior experience dismantling a digital camera, it could be quite tricky.
HERE is a service manual that should help. Its not the A610, but they are similar.
If your camera has a plastic ring around the lens, then it should be quite simple. Use a jeweler's screwdriver and try to pry out the ring. Once that is done, it should be easy enough to remove the lens barrels.
However, like I said, if you are not too familiar with this, it is best that you get it done by a pro. If it costs too much, then try giving it a shot yourself (nothing to lose anyways), and if you should screw up, there is always the option of buying a new camera :)
May 09, 2008 | Canon PowerShot A610 Digital Camera
Canon EF 75-300mm Lens Logo
431 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
