Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
Fluid is the fluid toxic that is in the tv
  • LG Master
  • 8,617 Answers
Yes its toxic if ingested by animals.It's the same as automotive engine coolant. Its the coolant for the CRT's it can also cause severe damage to the circuit boards solder if its allowed to set onto the circuit boards.
Posted on Jul 15, 2010
How to change steering fluid
Use a small hose and siphon it out, then replace with new fluid. I do not suggest siphoning with your mouth, its toxic and tastes really bad, most auto parts stores carry an inexpensive device to siphon out liquids.
Dec 02, 2013 | 2006 Chevrolet Uplander
What is the fluid leaking out of my television?
ITS GLYCOL AND TOXIC TO THE TOUCH---DEEP SIX THE SET AND GET IT OUT OF YOUR HOUSE-YOU WILL ABSORB IT BY TOUCH AND IT IS CONCENTRATED ENOUGH TO KILL SMALL CHILDREN OR PETS
Your mistake was opening the sealed area not meant to be opened, others have made the same mistake.
This is the reason (the glycol) why major landfills all over do not allow these sets to be dumped in the dump.
you went from bad to fatal and toxic waste cleanup.
Sep 02, 2012 | Hitachi 60SBX78B 60" Rear Projection...
Philips Magnavox 9P6040C104 Image Issues
If glycol issue screen will not be black and white but yellow etc.
(I can tell you simple way to know if glycol is bad)
This is toxic stuff so not likely a do it yourself repair.
If convergence issue-it will look 3d etc--
Kits are sold by model number on the internet for this--need to be able to get at the parts and be able to do good soldering etc.
Apr 15, 2012 | Televison & Video
Where to buy projector light fluid for a phillips tv
The liquid is called Glycol---very toxic stuff!
Suburban Electronics (has internet catalog and 800 number) sells it in plastic bottles.
If you have never done this take precautions not to get it on you--gets on your skin and is absorbed into your body--this is the reason most landfills will not allow these sets to just be dumped.
Apr 02, 2012 | Philips Televison & Video
Is fluid/coolant inside intelifocus lenses toxic?
If the set is rear projection with 3 large black lens inside---there is a sealed (if it is not leaking) area just below the lens-----the liquid in these sets (not in regular or plasma or lcd sets) is Glycol---like anitfreeze but ten times more toxic and concentrated.
Like antifreeze it is not allowed to be disposed of in a landfill and if found in a set do not touch as it will be absorbed into you skin.
VERY TOXIC STUFF.
Mar 22, 2012 | RCA Televison & Video
Hi, Can I throw out the differential oil just to
All used fluids from cars need to be turned into recycling centers or your local service station. Differential fluid is toxic.
Jul 11, 2011 | 2003 Chevrolet TrailBlazer
My vs-50609 tv screen will lose color then shut off then when it comes back on my convergence is way off
could be a fluid leak, many of these old mits will leak fluid out onto the boards and have crazy issues. look inside for the toxic fluid on your circuit board with a bright light.
here is my convergence tutorial if this helps, but look for fluid as i bet you have some.. if its a small amount, you can clean it up with alcohol and maybe fix, if its a lot, it might be a goner
http://www.fixya.com/support/r5069371-mitsubishi_led_keeps_flashing_green
Let me know if I can be of further assistance.
Jun 14, 2010 | Mitsubishi Televison & Video
There is no picture, but sound comes through fine. after opening up the back I discovered only the blue lamp is working. This happened before about a month ago and there was a small amount of clear fluid...
Yikes!!! That fluid is glycol, a clear fluid used as a coolant for the CRT tube (lamp). If you have a leak, there's not telling how much damage could have resulted. For sure, you need to find which tube is leaking and get it out of there. Glycol is very toxic, if you have ever heard or read the warnings about automotive antifreeze solutions of years ago, this is the same stuff, just in a pure form. Keep pets away from the area while you work this problem out.
Mar 15, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Hit wrong TV remote button, knocked out HD programming
You have multiple issues. The shadows are likely convergence IC solder connections breaking or the ICs actually failing. If you can bump the tv to get it to re-align, it just needs resoldering. If it doesn't snap back, it needs new ICs. The channel issue is less common and could be a number of things. You may want need to just autoprogram again to, but may have a fluid leak issue. You can unplug the tv and remove the back panel to inspect for fluid on the signal board (board with tuners, where cable plugs in).. DON'T touch the fluid, highly toxic stuff. Take a bright light and see if any drops have made it down to the board. If so, the severity of the leak will determine the repairablity. Try using a VCR or cable box to bypass this problem if no fluid leaked, that is the best (cheapest) way around it.
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
No image in blue gun assembly
the fluid in the bule gun is cloudy therefor the image you need to replace the fluid (coolant) inside the gun. the fluid is toxic (eytholene glycol). so have a tech do this for you. the repair may cost $ 325.00 or so.
Feb 22, 2008 | Akai PT5598HD 55" Rear Projection...
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
172 people viewed this question
Computer Repairing
Computer Repairing
