Question about Video Game Consoles & Games
Psp d-pad works fine in start up menu and game menus. But when you actually play the game, characters move in a diagonal direction.
  • 149 Answers
Time to take it apart and re-align the d-pad connections inside.
Posted on Apr 20, 2008
When i try to play any game on my psp the joystick keeps moving down....and i took out the joystick and still does it...i play another game like final fantasy 7 on my psp that doesnt use the joystick and...
if you are facing problem in psp then just don't worry........... you can fix it with the help of repair guide you can download it and solve your problem easily...........
i will give you the link to download i hope it will solve your problem
Click Here to download
Dec 08, 2010 | Sony PlayStation Portable (PSP) Console
Directional buttons work fine, until I start playing a game
Ok. navigate to system settings and scroll down to RESTORE SYSTEM SETTINGS, after that turn off your psp and wait for about 3 minutes and turn it back on.
Write back if this doesn't help.
Apr 18, 2009 | Sony PSP (Piano Black)
The analog works fine in the options menu but when
Try calibrating your PSPs analog stick, here's how: 1. Go to Settings>System Settings 2. With the System Information screen displayed, rotate your analog stick in a circular motion (clockwise and counter clockwise). This will adjust the analog stick's range of motion. 3. Exit the Settings then run your game and test the analog stick. (it should be working well by now)
I hope this helps.
Apr 12, 2009 | Activision Video Game Consoles & Games
My analog stick is stuck in the upwards direction. Every time I play a game, the character in the game always moves up and in the game menus, the highlighted option always keeps moving up. I really don't...
Sony is full of it. Yes you can repair it. All you need is a brand new nub (joystick). You can find it on the net for about $5 less shipping depending on your model it is not hard to replace. On a phat (old school psp there are seven screws holding the faceplate. Once the faceplate is off there are two screws holding the nub in place. The slim is almost the same there is seven screws holding the faceplate but the only difference is the last two screws you have to take off is on the top. And once the faceplate is off it's the same two screws holding the nub in place. Replace and screw back in.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Console
Directional buttons for PSP not working.
Star wars: force unleashed was a bad game... anyways:
Maybe the disk isnt read rite by your psp. maybe the disk is wrong?
Or it could just be that you dont use the directional buttons for gameplay, just the analog stick. XD
Dec 30, 2008 | Sony PlayStation Portable (PSP) Console
My psp won't play any games properly
Loading a custom firmware will solve this problem, because this problem is related to your PSP's firmware that's why it wont play any game at all...
Dec 14, 2008 | Sony PlayStation Portable (PSP) Console
Psp menu problem
Ok, your psp CPU clock speed is set to low speed.. 2 way to change:
1. If your psp has VSH menu enable.. : press "select" button, a small window will appear, otherwise its set to "disable".. See at "CPU CLOCK XMB" must set as "default". use left-right d-pad to change it. if vsh menu is disable you can try 2nd way.
2. Boot PSP under Recovery menu ( Hold R-trigger when turn on your psp ).. under M33 menu select "CPU Speed" then press "X", select "Speed in XMB" and "Speed in UMD" to setting as "Default" by pressing "X" button a few times.
Hopefully this help.! Pls post back should you need additional information, and also Show your Appreciation, to help other USER.
http://e-arena.blogspot.com.
Nov 06, 2008 | Sony PlayStation Portable (PSP) Console
Psp trouble
Hello, can you please explain in more detail about what is happening? Maybe if you were playing a lot of PSP, your keys might be jammed up in the circuit boards and when you play a game, some things are kind of pushing it to move the character.
Second question, in the main menu, is anything moving by itself?
Jan 26, 2008 | Sony PlayStation Portable (PSP) Console
PSP unresponsive
Hi Flying back,
I think your PSP may have had a confrontation with moisture. It sounds like the D-pad has one of the circuit pads shorte together full time. If one of the direction pads is always on, it will ignore the rest or add to them for a diagonal move. You need to open up your PSP and Look closely at the circuit pads for a form of short circuit across from one side to the other. you can scratch the short away if you find one. This should help. Good luck.
Dec 02, 2007 | Sony PlayStation Portable (PSP) Console
Directional Button and L Button Problem and another problem.
I think there might be a problem with your configuration, remove all plugin then try to restore to default setting on setting menu. and/or if your psp installed Custom firmware, the umd speed are set to fast. do this via recovery menu (hold R trigger while turn on psp). you may need to fix L button if it is stuck. you may consoder sending it back to Sony for repair.You can call SONY support at 1-800-345-7669. hope this helps.
Nov 06, 2007 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
