Liteon DVDRW SHM-165P6S ..Insert disc in unit, click on drive, computer asks for disc to be inserted
  • 871 Answers
Disconnect drive and make it 2nd master. check for any firmware upgrade/update. try it again...
Posted on Apr 20, 2008
When i want to burn dvd on samsung dvd writer, it ejects the disc and when i insert data disc into the drive, it shows no disc. so, what is the problem?
try using a different type/brand of cd/dvdrw you might have a bad batch of cd/dvdrw or test all leads that attach to your dvdrw any faulty lead will result in computer error or control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 19, 2010 | Samsung SpeedPlus DVD-Writer 20x, Black ...
DVD disc door won't open.
have you tried going to my computer right clicking on the drive and pick eject from the menu? if this doesnt open there is an emergency lock release on the from it is a very small hole in the face of the deck use a small paper clip or stiff piece of wire and insert it into the hole and push lightly this will release the door for you
Aug 29, 2010 | Lite On LITEON 8X DVDRW +/- Burner
Dvd drive wont open , can hear motor working but drive wont come out. we believe the cd holder isnt shifting up/down to allow the drive to activate & open
Turn the computer off,Remove power cable.Use a peper clip insert it through a hole infront of the dvd drive this will eject the door.Make sure once this is opened the tray is aligned properly,slide it in and out.Push it in all the way then power up the computer.This may work for a while,before it goes again,so you might have to replace it.
Good Luck
Jan 17, 2010 | Lite On SHM-165P6S DVD RW Dual Layer...
Burning images to DVDs
you need to launch the lightscribe software, insert the disk upside down (opposite to what we use when burning data into disk), select the image in the software and start burning.
Jul 07, 2009 | Computers & Internet
On my liteon 5005, i press''eject'' i hear clicks, but the tray will not open.help!!!!
Take a paper clip, bend it, and insert it into the small pin hole on the front of the player. It should be next to the eject button. This will open the tray up manually.
Mar 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Liteon HDD/DVD recorder/player
lite-on dvdrw in model HD-A760GX will not recognise dvd disc. KEEPS STATING TO INSERT BLANK
Jan 26, 2009 | Lite On SOHD - 16P9S Internal DVD Drive
LITEON LVW 5001 doesnt recognize DVD's
Laser either dirty or starting to go.Try cleaning laser with commerical disc cleaner,put a drop of rubbing alcohol on brushing.Laser can be cleaned manually with a Q tip dipped in rubbing alcohol but this requires opening burner.If you do this MAKE CERTAIN ELECTRICAL PLUG IS PULLED,lasers cause nasty burns.
Some times the problem is just the brand of disc,some brands don''t work in Liteon's.
If laser is going the burner can be replaced.Most of the Liteon 5001's used Liteon 401s burners,411s or 451s dvd burners all will work.The dvd burners mount from the bottom PC burners mount from the side so they would have to be adapted,many PC burners won't work in these older liteons some freeze up the second you hit fast forward.
Jan 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
I have an error 39 on my LITE-ON DVDRW SHM-165P6S and I dont know what it means
I have done some researching and found the following information about the meaning of the error code you are receiving and instructions on how to fix it. Please let me know if this does not solve your problem or you need further assistance. Another place to check is the microsoft website which gives detailed instruction about fixing the problem also. The error you are receiving could also be known as an error 31 and has some other errors you might receive. Let me know if you need further assistance.
If you do not mind please rate my help after I have helped you fully, I would appreciate it. Thanks
Jul 16, 2008 | Computers & Internet
LOST INSTALATION DISK
Hi, check here and you will find the drivers you need for your dvdrw. Thanks! /D
http://www.nodevice.com/driver/company/LiteOn.html
Apr 27, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Computers & Internet Logo
252 people viewed this question
David Payne
David Payne
