Question about Dacor Preference RSD30 Gas Kitchen Range
I self-cleaned my oven yesterday and now the oven wont heat up I do not have a manual
    Brigadier General:
  • 7,191 Answers
You can download the manual by clicking this link:
http://www.dacor.com/uploadedFiles/Dacor/The-Dacor-Kitchen/Recipes/Cookbooks/RSD,%20RSE.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from: http://get.adobe.com/reader/
For more details, click here
Thanks for using FixYa
Posted on Jul 17, 2010
3 Suggested Answers
scottowa
  • 87 Answers
SOURCE: My Dacor ER36D wont heat after self-cleaning. What should I do?
I would guess you probably have a element out. These stoves are suppose to be self cleaning but I can't tell you how many times I go to repair a stove and it's usually after self cleaning. I'm not in favor of self cleaning becuase it gets SO hot for SO long it really stresses out everything in the stove. If your element is exposed, look for cracks or any iregularity. If you can't see it, it will be under the bottom pan and that usually comes off with 2 screws in the back. Elements can be found about anywhere. Here is one spot.
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Posted on Feb 15, 2009
leroyal
  • 2120 Answers
SOURCE: Oven won't heat. No gas smell. Broiler and stove work.
Bad oven control circuit board. Look up on eBay
Posted on Feb 21, 2009
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Oven (indicator light) clicks on and off
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
Nov 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
I have the same problem with my RBS305PVS... i self cleaned the oven and now it wont heat..... i tried the 2 pole breaker idea.. no go.. i worked yesterday.. cleaned it.. it no workie now please send me...
A common problem when using self-clean functions.
It destroys parts.
Remove the rear panel from the oven and replace the thermal fuse that blew because of too high temperature.
Dec 12, 2010 | Ovens
Ask a question yesterday did not get an answer .i will ask again kenmore self cleaning oven tried to clean pressed button door locked .after ten minutes oven did not heat up to clean did i miss a step that...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 09, 2010 | Kenmore Ovens
Hi! I am trying to self clean the lower oven in my built in oven. Yesterday I did the top one with no problem. Today I started it & it seemed to go correctly but it has been making clicking noises. The...
heatman101
Aug 24, 2010 | Thermador SC302T Electric Double Oven
Oven wont come on
Cleaned the oven yesterday with self clean and the next day while cooking on the top it just stopped working
Dec 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Single thermador oven will not heat
very common/ never use self clean just before holiday you may be eating out .. after the clean cycle or during it may have blower the hi limit ( on the back of oven.. this is a one time and you must replace it with same tempt .. ( remove oven set it on small table of chair / cable is short. remove thermo and replace . reinstall and do some baking mm
Dec 03, 2009 | Kitchen Ranges
My range is actually the RGB746 self cleaning gas
oven don't stay on and it takes a long time to heat up
Nov 21, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven wont heat
That depends if the oven is electric or gas.
If it is electric, it can be heating element, temp probe, or control knob/buttons, board and wiring.
If it is gas it can be the igniter (check spark) , the thermostat, the safety valve that prevents accidental gas flow, or the control.
If the oven has self cleaning cycle, check that it is not stuck on self cleaning, try unplugging for a while and restarting self cleaning cycle in that case.
Check also What is wrong with your Range/Stove/Oven?
Mar 29, 2009 | Ovens
My oven will not heat up at all.
make sure your cooking timer is on manual....
Feb 01, 2009 | Whirlpool RBS305PD Electric Single Oven
Dacor Preference RSD30 Gas Kitchen Range Logo
88 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
