Question about Sony Reader Touch PRS-600
I am getting the "unable to access ebook store Check your network settings to ensure you have access to the internet." i am using Windows 7; Sony reader PRS-600 Would appreciate help! Thank you Joanne
    Problem Solver:
  • 5 Answers
Has this happened to you before? If you access the Reader Store from your regular Internet Explorer can you access it? If that is the case, try downloading the Reader Library software once again.
Posted on Jul 16, 2010
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
Tip
Cannot access internet!!!!!
Using Windows Operating Systems:
Windows XP:
1.Powercycle equipment (Unplug power wait 15 seconds then plug back in)
2.Go to Start/Run/Type ncpa.cpl then hit ok.
3.Double Click Wireless Connection (Router Connection) Hit Properties.
4.Click on tcp/ip then hit Properties
5.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
6.Restart Computer, If still unable to access internet check you Firewall:
Start/Control Panel/Windows Firewall/Change Windows Firewall Settings/Turn Off not recommended.
7.Last Go to Start/Run/CMD/Hit ok
A.Type netsh int ip reset reset.log Press Enter after every Command
B.Type netsh int ip delete arpcache
C.Type netsh winsock reset
D.Type ipconfig /flushdns
8.Restart Computer
9.If still having issues check for viruses or malware in your computer.
10..Refer to your manufacture.
Windows Vista/7:
2.Go to Start/Search Bar/Type ncpa.cpl then hit Enter.
3.Right Click on your connection usually (Wireless) then click Properties.
4.Uncheck Internet Protocol Version 6 IPV6
5.Click on Internet Protocol Version 4 IPV4 Then hit Properties (Do not uncheck IPV4)
6.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
7.Restart Computer, If still unable to access internet check you Firewall:
A.Start/Control Panel/Security/Allow Program Through Windows Firewall/General Tab/Turn Off.
8.7.Last Go to Start/All Programs/Accessories/Right Click on Command Prompt then hit Run as administrator and hit continue.
10.Refer to your manufacture.
on Jan 11, 2011 | Computers & Internet
Tip
IP conflict on my home network
Hi.
If there is an IP conflict, that means that two different devices connected to your home router are getting the same IP. In this case one or more connected devices will have limited connectivity, as they will be unable to access network resources.
The following troubleshooting must be performed on one networked device at the time.
Check if the internet provider that you are using allows DHCP. Most broadband providers use DHCP.
DHCP (dynamic host control protocol) means that the IPs, instead of being static are being assigned each time by the router.
If you use DHCP, then ensure that all devices connected to the network are not set on Static IP. If there is a device that must be set on static (eg. a network printer), then change manually the device IP to a different one. Ensure that the new IP belongs to your network range.
Reset the network settings on all connected devices. On computers remove the network adapter from the installed hardware devices list in control panel.
Restart computers one by one, after removing the adapter, and allow the network card to reinstall, using driver disk when needed (ensure that you have the drivers first). It will set itself to DHCP by default.
If that does not work, then you can try changing MAC address on Windows. The MAC address is an unique identifier that is assigned by manufacturer to any Ethernet adapter. The MAC address is used by the router to determine IP. To this purpose see: Changing MAC addresses on Windows .
If still no luck , then the next step would be resetting and re-configuring the router again, using the settings given by your ISP. Ensure that you have your Internet Service Provider configuration settings before resetting the router
At this point it may be worth testing a different Ethernet adapter (eg an USB adapter), rather than resetting the router.
If all that does not work, then either the router, or one of the two network adapter is probably defective. In some case virus or malaware can also cause IP conflicts.In that case ensure that the computer is clean, and eventually replace the router, after testing PC network adapter.
Note:If your home LAN uses static settings instead of DHCP, simply check that the IP set for each device is different.
Regards.
on Feb 18, 2010 | Computers & Internet
Which service has to be active in order to access my network?
In order to access your network, you need to make sure that your router or modem is turned on and Internet is working. Additionally, you must ensure that network adapter on your computer is enabled.
To know how to connect to Internet, refer to the instructions mentioned on the links below:
http://windows.microsoft.com/en-in/windows/connect-internet#1TC=windows-7
http://www.wikihow.com/Connect-to-the-Internet-Wirelessly-in-Windows-7
In case you are facing issues connecting to Internet, refer to the link below for troubleshooting options:
http://windows.microsoft.com/en-in/windows/cant-connect-internet#1TC=windows-7
GuruAid.com
Jan 07, 2016 | Microsoft Windows 7 Professional Service...
Why after installing webroot on my hp pavilion with windows 7 I can not connect to Internet it says " unable to connect to proxy server" ?
The anti-virus has set up a firewall which has disabled your internet access. Go into your Webroot console and go to settings and firewall and set it to make an exception for incoming network connections.
Sep 22, 2014 | Webroot AntiVirus with AntiSpyware &...
I have an ebook notebook 7 but it wont load the internet even though it is saying im connected with a strong signal. any advice?
just because you are connected to a wireless network does not necessarily mean that you can access the internet. Can you access the internet from another wireless device using the same wireless network. If you can then the problem lies with whatever browser you are using and maybe your firewall. Please reply with what windows version you are using and what browser and firewall is on your ebook
Mar 20, 2011 | ASUS Eee PC 1000HE Netbook
Lap Top access - unable to access internet on lap top
1.Powercycle equipment (Unplug and plug back in)Wait 15 seconds then plug back in.
2.Check connections the Ethernet cord from modem should be plugged into back of router into internet port.
3.If modem runs off signal from a local tower and there is not sufficient signal on the modem you will need to contact your ISP ( Internet Service Provider) to check for outages if not skip to step 4.
4.Open your network connections window.
A.Windows XP:Start/Run/Type ncpa.cpl this will bring you to network connections.
B.Windows vista/7 Start/Search bar Type ncpa.cpl
5.Windows XP:Right click on Local Area Connection and click properties,
A.Click Internet Protocol and hit properties ensure Obtain ipaddress automatically and Obtain DNS service automatically is checked if not check both and close window.
B.Windows Vista/7 Right click Local Area Connection and click Properties, Uncheck Internet Protocol Version 6 and click on Internet Protocol Version 4 and hit Properties Ensure Obtain ipaddress automatically is checked as well as DNS server.
6.You will need to manually renew ipaddress if this does not work
A. Windows XP:Start/Run/Type CMD and hit enter,
B.Type ipconfig /release
Then type ipconfig /renew then restart computer
A.Windows Vista/7 Start/All Programs/Accessories/Right click Command Prompt and hit run as administrator.
Then type ipconfig /renew restart your computer
7. If this does not help run an Antivirus. Hope this helps Happy Thanksgiving
Nov 26, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
When I try to install my ebooks library for reader it says to check my internet connection, which is fine!!! it will not finish the installation.
If attempting to connect to the Reader (eBook) Store by Sony on a computer that is connected to a network through a proxy server, contact your IT support specialist for assistance in configuring your proxy server settings to allow access to the Reader (eBook) Store by Sony. It is not possible to adjust these settings through the Reader (eBook) Library software.
  1. Check your security software settings. Some security settings may not allow the Reader (eBook) Library software to access the Reader (eBook) Store and will need to be adjusted to allow access to the Reader (eBook) Store. Determine if the security software is causing the issue.NOTE: Various different Internet security or parental control software may block access to the Reader (eBook) Store. Some software may request a password to unblock the store site. If a password is requested, enter your password to access the site.
    1. Temporarily disable the security software.
    2. From in the Internet Explorer software, on the menu bar, click Tools , then click Internet Options .
    3. In the Internet Options window, click the General tab
    4. In the Browsing History section, click the Delete... button.
    5. In the Delete Browsing History window, in the Temporary Internet Files area, click the Delete files... button.
    6. In the Delete Files window, click Yes .
    7. Attempt to access the Reader (eBook) Store Web site through the Reader (eBook) Library software.If you are able to access the store with the security software disabled, the security settings will need to be adjusted. If you are still unable to access the store, continue with troubleshooting.
    8. Re-enable the security software.
    NOTE: The steps to adjust the security software settings varies by manufacturer. Consult the help files of the software or contact the manufacturer for assistance. A list of contact information for some popular security software.
Dec 26, 2009 | Sony Reader Pocket PRS-300
Have a sony vaio pcv j120 that was purchased in 20001 7 nvr used
yes. it might be a good ideea to upgrade os, windows 2000 or windows xp. try to instal a new network card if you think that your nic is damaged. search for a new pci ethernet card.
Feb 22, 2009 | Sony VAIO PCV-J120 PC Desktop
Sony Reader Touch PRS-600 Logo
288 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
