Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
I HAVE A MAYTAG MBD9600AWS DISHWASHER AND NONE OF THE LIGHTS COME ON THE CONTROL PANEL CANT CHANGE CYCLES
    Genius:
  • 1,075 Answers
Not sure what you are telling me,have you checked the power supply.adrian,,,,,
Posted on Jul 15, 2010
Yes, Go to a real site that is not pure come on, to get your read their cheezy ads.
Posted on Jul 21, 2010
Maytag MDB4651AWS Dishwasher will not start.
Do you ever hear the fill solenoid click on to begin the filling. That is the first thing that has to occur. The water supply generally connects right to that solenoid. Ohm out the solenoid coil. ( breaker power off)
May 21, 2012 | Maytag Dishwashers
I have a 4 year old Maytag MDBH945AWW and the panel lights come on and I can select cycles... but the dishwasher wont start. I tried holding the start cancel button, tried turning the breaker off for a...
What you need to do is read for continuity and power across the door latch switch. (2 white wires) AND 2 Black wires Both wires must read continuty at the control panel connectors to the power source terminals for the unit to start. Since the control panel lights up I have to assume that the black wire from the door switch has 120VAC on it.
There is also a turbidity sensor that can cause this: http://www.appliancepartspros.com/part_details.aspx?part_id=4114286&image=1
I an not telling you to change parts. You really need to use a meter and follow 120VAC power to find out where it stops when it should be passing through a component.
If you can interpet this diagram....
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1318099&pkw_=basket&model_id=5177084&NewWindow=1
I do not think at this point you need a control panel. It is possible but... the door switch and the thermistor will prevent the unit from starting.
This is ONE source for replacement parts.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177084
There are numerous parts sources on line and locally.
Don't give up on your dishwasher too soon. 4 years is about mid life for your dishwasher.
Thanks for choosing FixYa.
Kelly
Sep 23, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
May 18, 2010 | Dishwashers
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Maytag dishwasher model #MDB6650AWW no lights on the conrol panel Door switch has power.
if the door switch has power and you cant get the dishwasher to do anything then you will need a new control.. ..
Feb 20, 2009 | Maytag Dishwashers
Dishwasher works only in Rinse and no lights on the Control Panel
I HAVE SEEN THIS BEFORE ON SEVERAL DIFFERENT MAYTAG MODELS AND EACH TIME, IT HAS BEEN THE ACTUAL TOUCH PANEL WHERE YOU MAKE YOU SELECTIONS. I HAVE PROBABLY SEEN A DOZEN OF THESE IN THE LAST COUPLE OF YEARS. HOPE THAT HELPS.
Jan 29, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Dishwash - No lights will light up on the control panel
first off ck the breakers ofr tripped breaker, next remove lower acess panel and on right side is main wire connection remove box cover and make sure connection is good. ck fro 110 v there if not you got an electrical issue. next would be to check the door switch assy's.
Mar 08, 2008 | Dishwashers
Control panel lights OK; Won't start into cycles
Hey, just had the same problem with my 9150. Moisture got into the electronic key pad. $300 to replace it. I was 5 months out of warranty.
I called 800-688-9900 and Maytag agreed to cover the part and we have to cover the labor. Not completely satisfied but a little bit helps.
Jan 09, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
231 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
