Question about Dometic RM2193 Compact Refrigerator With Ice Box
I have a Dometic 2193 3 way fridge. It works
I have a Dometic 2193 3 way fridge. It works great on AC power. It does not work on propane as well. The flame was not mostly blue on high so I cleaned the burner and burner jet as recommended in the owner's manual. The flame is now a lovely shade of blue :) I put the fridge on AC and cooled it to 40F. I switched it to propane and after 4 hours it was at 50F. The flue baffle is hot to the touch. The outside temp is 85-90 and quite humid so if I had turned the fridge off entirely after the same amount of time the fridge would have been much warmer inside. It seems like the propane is working but not enough. Any help would be appreciated.
  • 3 Answers
The flue baffle was the solution that worked for me as well. Below is a response I posted to a similar post.
I had a similar problem. The flue would get hot and the cooling tubes would get "warm". The refrig would get a LITTLE cool but nothing to be of any help.
I solved it though...it turns out there is a "flue baffle" (twisty little metal thing) that is supposed to hang in the inside of the baffle. It hangs from a screw found on top of the baffle and it is supposed to hang down.
The screw that held mine was corroded and flue baffle had fallen into the baffle and landed on top of the burner.
I ended up fishing the flue baffle out of the top of the baffle with a coat hanger, then rehanging it using a new screw. That solved my problem.
Not sure if this will work for you or not but good luck.
By the way, you can find an owner's manual with a diagram showing the flue, the flue baffle, and the piece of metal holding it here:
http://www.fourwheelcampers.com/DometicRefrigerator.pdf
Look on p.9, figure 9. Item C is the flue baffle and the wire holding it. Item B is the screw that was corroded on mine, and ended up dropping the baffle down to the bottom of the flue.
Below is a link to some generic directions on solving fridge-related problems. I found it to be VERY useful.
http://rvmobile.com/Tech/Technical.htm
Posted on Jul 28, 2010
  • 906 Answers
Go up on top of your coach, remove the refrigerator vent. That will give you access to the chimney on the fridge. Remove the flue cap, and there will be a little metal hook hanging on the side. Pull this up, and there will be a spiral baffle attached. Look for debris on the baffle, clean if necessary. Also, the bottom edge should be straight, not chewed up.
Also check your orifice in the burner tube as well. If the orifice is clogged, it may not allow enough LP gas to flow, giving a low flame.
Posted on Jul 18, 2010
  • mexifin Aug 04, 2010
    I would probably test the thermocoupler or change it this will affect the cooling of your refridgerator a $ 20 fix may take 20 mins. to change.
Dometic rm2611 freezer works fine on propane but fridge doesn't cool
move temp sensor to middle of coil if same replace temp sensor
Mar 28, 2014 | Dometic Refrigerators
Propane mode on my rm2554 dometic 3 way fridge hasnt worked in a long time now ac has stopped working, fuses and breakers all good
clean out lines to LP if ok no clicking bad board if clicking check for cobwebs and ac check heater element
Aug 12, 2013 | Dometic Refrigerators
Help!!!
check power at camp ground if too low will not work either ac or LP board works off of 12 volts
Jun 24, 2013 | Dometic RM2652 Refrigerator
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
Not working on propane
Shut it off, (propane) and used compressed air to try and blow up that stack and clean out any rust that may be in there, as well as check for baffle hooked at top of stack, and hangs down inside the tube.
Jun 01, 2010 | Dometic RM2193 Compact Refrigerator With...
HOW TO START / OPERATE THE FRIDGE
Here's a link to download PDF file for your fridge.
http://bryantrv.com/docs2/docs/rm2193.pdf
May 06, 2010 | Dometic RM2193 Compact Refrigerator With...
The fridge will not turn on. Should I be turning on the 100 switch, even if the camper is plugged in, and the lights are working?
Do you mean the 110VAC switch? Unless you are running the fridge on propane, it will need something to power it and if the camper is attached to power the fridge can be run on AC.
Sep 01, 2009 | Dometic WA3210 Compact Refrigerator
No propane
Yes it can also run on 120 AC and 12 volt DC
Here is the website. If you need help in understanding let me know
http://www.campingworld.com/shopping/item/dometic-rm2193-compact-refrigerator/13473
Apr 21, 2009 | Dometic WA3210 Compact Refrigerator
Dometic RM2193 Compact Refrigerator With Ice Box Logo
1,626 people viewed this question
Top Dometic Refrigerators Experts
Sheldon Dedek
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
