Question about Soyo DYLT032D 32 in. LCD Television
Soyo 32 inch TV, no sound
I have a soyo 32 inch tv with no sound, everything else works fine?
    President:
  • 1,099 Answers
First check that any muting control is not activated. This might be
a button on the remote or set itself. If you have a headphone jack, it
may have dirty contacts as plugging in a headphone usually mutes
the speaker.
If the set is mono or only one channel of a stereo set is out, then
check for bad connections to the loudspeaker. Test the loudspeaker by
disconnecting one of the wires (with the power off!) and measuring its
resistance with an ohmmeter (it should be less than 100 ohms - probably
less than 8 ohms). Or momentarily touch a 1.5 volt battery to the speaker
terminals - you should get a click or pop from the speaker.
Next, trace back from the speaker output terminals to the circuit board
and look for bad solder connections or a loose or dirty connector.
If these tests do not reveal anything, you probably need a scope (or
audio signal tracer) and schematic. Or at least the part number off of
the chip. Is the final amp a chip also or just a transistor? Have you
tested the transistor? If there is little or no buzz from the speaker,
that would indicate a problem fairly near the output. If the tuner/if were
bad, I would expect some noise/humm pickup from the low level audio stages.
Get the part number off of the chip. If it is in a socket, check the
contacts for corrosion or looseness.
Hope this helpout.....
Posted on Jul 14, 2010
  • midevil6 Mar 23, 2011
    Check the main board. upper right hand side look on back of board. I have the same issue no sound board is burnt the part number you need is LRM303360-0001. Hope this helps
What wall mount fits a Soyo TV...MT-PRTPT3208NB
Contact the authorized dealer for Soyo. They can provide you details.
Jul 01, 2013 | Televison & Video
I need a mother board for my 32' soyo
Since you did not intimate model number of your Soyo 32 inch tv so click ShopJimmy.com and put your tv model number in search bar to locate required main board for tv.
Hope these info will help you.
Thanks.
Dec 13, 2010 | Panasonic Televison & Video
My TV won't turn on
Ur tv have LED front panel power indicator light blinking?Or completely dead,no LED light indicator at all?Check ur power outlet source.Yes,than ur power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 28, 2010 | Soyo DYLT032D 32 in. LCD Television
Soyo DYLT032D - grey box in corner, no main picture or sound
I am having the same problem. Does anyone know the solution?
Oct 29, 2009 | Soyo DYLT032D 32 in. LCD Television
I need a remote for a soyo 32 inch tv or a code that works with a universal remote
The RCA RCR312wv sold at Wal-Mart for about 7 bucks has 2 SOYO codes and the second one worked on my 32" SOYO
Oct 27, 2009 | Soyo DYLT032D 32 in. LCD Television
My Soyo DYLT032 has power but no picture or sound
I HAVE FOUND 2 2200uf CAPS ON THE POWER SUPPLY BOARD THAT ARE PUFFED UP. CHANGING THEM USUALLY SOLVES THE PROBLEM. THERE'S ALSO A RESET BUTTON ON THE MAIN BOARD YOU MAY NEED TO RESET AFTER CHANGING THE CAPS.
May 30, 2009 | Soyo DYLT032C 32 in. LCD Television
Problems with Soyo DYLT032C 32 in. LCD Television. The TV will not turn on, I have un-plugged it and plugged it back in, in hopes it would re-set the tv. Do you have any suggestions?
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Dec 10, 2008 | Soyo DYLT032C 32 in. LCD Television
Sound is distorted on 32-inch GE TV when auto tuned
Problem in the IF section of the tuner. May need to just replace the tuner pack...accordianman
Feb 19, 2008 | GE 32GT740 32" TV
Soyo DYLT032D 32 in. LCD Television Logo
324 people viewed this question
Top Soyo Televison & Video Experts
Jaime Hernandez
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
