Question about Brother Office Equipment & Supplies
I was given a MFC fax, scanner and copier machine. The serial number is U56580C3J298847. The owner left it at in the garbage can. The property clean-up crew gave me the machine. I need a manual. It looks fairly new. No cords, no connectors, etc. Where can I buy the AC cord? Thank you, Sergei Goncharoff gofilment@att.net
  • 137 Answers
Find a local Brother Dealer they can help.
Posted on Aug 14, 2010
I cannot print with only black ink
STEP 1: OPEN THE PRINTER PROPERTIES:
WINDOWS 98/ME/2000
A. Click on START -> SETTINGS -> PRINTERS
B. Right click on your Brother machine (example MFC-XXXX where X = modelnumber of your machine) and left click on PROPERTIES
WINDOWS XP
A. Click on START -> CONTROL PANEL -> PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE, then PRINTERS AND FAXES)
B. Right click on Brother machine (example MFC-XXXX where X = model number of your machine) and left click on PROPERTIES.
WINDOWS VISTA
STEP 2: CONFIGURE THE PRINTING PREFERENCES
Depending on which version of the driver you are using, you will need tocomplete one of the following sets of steps.
A. If using the Brother Original Driver:
i. On the GENERAL TAB click the button for PRINTING PREFERENCES.
ii. Click the ADVANCED TAB.
iii.. Choose COLOR
iv. Click APPLY -> OK
v. Click OK to close the Printer Properties window. Your printer will now print in grayscale.
B. If using the Vista built in Driver:
ii. Click the PAPER/QUALITY TAB.
iii. Choose COLOR
Nov 01, 2010 | Brother MFC 420CN All-In-One InkJet...
I just changed my ink cartridges but now the printer is only printing black and white
WINDOWS 98/ME/2000
WINDOWS XP
WINDOWS VISTA
iii.. Choose COLOR
iii. Choose COLOR
Oct 31, 2010 | Brother MFC 240C All-In-One InkJet Printer
My brother printer/copier/scanner/fax machine is printing with a vertical line down each copy. What can I do to fix that?
check that the corona cleaner on drum unit is locked on correct side, if still line, check scanner glass, left side, see if white out is on glass, or some type of smudge on glass
Sep 22, 2010 | Brother MFC-8870DW Laser Printer
How do i send a fax ? mfc-240c and where to insert paper.
To send a fax, you need to have a working phone line plugged into the jack on the left hand side of the printer. If you are faxing one page, place it on the scanner bed (the glass) and close the lid, then press the Fax function button, type in the phone number to fax to, and hit Start.
If you are faxing multiple pages, it is the same process, but instead of placing the paper on the scanner, you would place it in the document feeder on top of the printer, and each page would scan through individually. (Make sure none of the pages are stapled or paperclipped together.)
Dec 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Check whether the MFC has faxes in
memory
1.Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it then do as above.
—OR—
If faxes are present, you can transfer them to
another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error message
I can't find the "50" as part of the "Unable to print" error. Usually when you get "Unable to print", it means there's a torn piece of paper, paperclip, some foreign object in the machine somewhere. Check under the scanner lid and inside the machine, look thoroughly; you may find a piece of paper blocking a sensor. If the error message continues, follow these steps before disconnecting the MFC so you won't lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in memory: 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1. Let me know if it helps!
Oct 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
82 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
