Question about Belkin (F5D7230-4) Router (587009)
How do I get my connection to stay on?
I have a belkin router model f5d7230-4 and I was wanting to hook everything up to my 360. Well..Ive got everything as the directions say but when I connect the router to my modem, the internet will stay on for only a minute or so, then it will go off, then it will come back on for a sec. Is the problem my router or my internet connection or the IP address?? Could someone please help me?? My address is ballinallstar22@hotmail.com. Thanks!!
    Sergeant:
  • 221 Answers
While the modem is connected to the router, and both are turned on, try unplugging the modem power cable for 30 seconds then plugging it back in, this will force the modem to recognize the router as a trusted device.
If this does not work, check to make sure the cables between your modem and your router, and between the router and your xbox are secure, and that they are in good condition. If they are older cables and the connectors are pulling off the end of the wire, replace them.
Next you can try connecting your xbox directly to your modem, once again, unplug the modem while connected and plug back in. If you still have the problem after this step, then you've narrowed the problem down to either the modem, or the network adaptor on the xbox.
Posted on May 03, 2008
My belkin wont connect, the light flashes orange and says no internet access. Everything is plugged in the right spot and we have rang the belkin company up. but no use. ???
reset it and then load the belkin cd before you hookup the router to the system and then when it tells you too then hook up the router,make sure to revert back to the way it was hooked up before you got the router
Feb 09, 2011 | Belkin Basic Wireless Router
Bad Belkin 54g Connection Problems!
reboot your modem then reboot the router that should fix it
Jun 26, 2010 | Belkin (F5D7230-4) Router (587009)
IWon't hook up to my modem
Try getting a different CAT5 cable.
Mar 20, 2010 | Belkin F5D7234-4 Router
How do i install my new belkin systyem when ive
yes you can use it.
first connect your Belkin router to computer with lan cable .
Then access it wityh this link.
http://192.168.15.1
user name as "admin" and password as "admin"or
blank or
"password"
then configure your router as your old lynksys settings.then save settings and restart .
Aug 22, 2009 | Belkin N1 Vision Router
Belkin F5D7230-4 not working anymore?
Well i think u r right, u must contact to Belkin support team (http://www.belkin.com/support/) or to from where u buy this. If router is in warranty period then u will get replacement.
Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Belkin g + mimo and xbox 360
are you typing the correct upper or lower case and not confusing zeros with the letter 'O'
Sep 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trying to hook up belkin wireless router to cable modem and don't know how the hook-up should be
If you have your pc connected directly to your broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
Aug 09, 2008 | Belkin Computers & Internet
Router and xbox 360
You connect the adapter to your Xbox 360
May 20, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My belkin router wont work :(
If you access your router, look at the wireless settings, you may need to change a setting to allow b + g connections, your laptop may have a 'b' adapter.
Mar 09, 2008 | Belkin (F5D72304F5D7000) Router
Belkin (F5D7230-4) Router (587009) Logo
43 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
