Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
I have Error 1 (Dishwasher leaks) in my Electrolux dishwasher. I already checked all solutions for this problem in Use & Care Guide, but steel have this problem. Please, send me wright solution for this problem. Thank you in advance.
    Problem Solver:
  • 5 Answers
Check gasket for proper fit, cracks, splits.
Posted on Sep 04, 2010
  • mucthetruck Feb 24, 2011
    Electrolux dishwashers have a defective sealant that brakes down after about 2 years and leaks from the joins in the external stainless steel 3 piece liner. The other isssue the have is the feed tube to the top water jet splits due to **** poor materials. The build qualily is pathetic and they leak like a sieve after a couple of years due to manufacture using **** sealant.
    They cant build front loaders either as the bearings in the tub disinegrate after 2 years . Of course the last the warranty period then they expect you to buy a new one. NOT BLOODY LIKELY, BUY A BOSCH DISHWASKER NEXT TIME
  • Phil Gar Mar 07, 2011
    I also have had problems with mine. I originally bought a floor model and it was only $500 so I thought - lets give it a try. I installed it myself and it is very quiet, but average at cleaning dishes. It also developed the error 1 code - I took it out and flipped it over and took off the pan and tightened the hoses. The problem went away for a while ( 6 months) , then returned. I took it back out and thought I could find the leak. (this was yesterday). It was also leaking a little on the floor toward the end of the cycle. I put it up on some 4 x 6's and took off the pan and ran it on a normal wash. After about 10 min it started dripping into the "pan area" . What I found however was that it was not from the motor, but was coming from the front door seal/pan. I took apart the front door ( remove the screws from the inside (but leave the top philips screws!) and ran it again. What I found was that at the corners of the door, water was running outside the seal, slowly filling up the front little lip, and then leaking out. There is a gray plastic shield below the lip held by 2 screws ( I think for sound insulation) which would then catch the water and channel it back inside the machine that would cause the error 1 code!. What I did at this point was open the door and lift part of the gasket from the bottom ( it was a little loose) and realized that it was allowing water to dribble out past the gasket, catch on the lip, overflow over the lip, and cause the problem. I then pulled out ~ 4 inches of the gasket, and put silicone in the channel, and reapplied the gasket. Also, I lifted the corner rubber gasket ( bottom corner where the hinge meets) away from the wall and then applied silicone. I waited overnight and reran the dishwasher this morning watching for the leak and- NO LEAKS! I also put a large swath of silicone on the gray plastic below the lip so water can't go into the pan and set off the alarm, and I also put a door vinyl weather stripping glued to the lip to add a little height in case it starts to leak again. Well - all is well now ? for how long? But I could at least see the problem (their design problem) It took me a few hours, but so far so good. If any major thing happens to this dishwasher again however, I will trash it and get a bosch or kitchenaid/kenmore elite. hope this helps
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
Electrolux dishwasher giving error code 1?
Good Morning Brian,
I understand that you are receiving an error code 1 on your Electrolux dishwasher, model# EWDW6505GS. Error 1 is stating that water has been detected underneath the tub. Check underneath your dishwasher by taking off the kick plate below the door. If you do not notice any water underneath the tub or any types of leaking, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker for 20-30 minutes. When the time has passed, restore power, and run any cycle. If you are still receiving error code 1, I suggest you contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 07, 2014 | Electrolux EWDW6505GS Fully Integrated...
Electrolux dishwasher leak detector light
This was a good answer. It reset the error. But once we started the washer up again it threw the same error. Next step, remove it from the cabinet and check for leaks.
Apr 10, 2014 | Electrolux 24 in. EDW5500DSS Stainless...
Wave touch electrolux error 01
Hi - Error code E01, typically indicates that a water leak has been detected under the tub. Unit may possibly need a hydraulic kit; however I would suggest contacting a professional to move forward accurately.
Oct 13, 2012 | Electrolux 24 in. EDW5505EPS Stainless...
Just installed and ran for first time. Dishwasher stopped with Error Code 04, Drying Damper not operating. Is there something I can do to fix it or do I need to call for service?
Hello.
I also own the Electrolux EWDW6505GS--0 {24'' Built-In Dishwasher with Wave-Touch® Controls}
On two occasions I have had the "Error 04
Drying Damper - Drying damper not operating"
In each case, I found the plastic 'ring nut' RETAINER in the upper right top of the machine had come loose. I simply unscrewed the retainer, wiped the area down, and re-screwed the ring on hand tight.
Sincerely,
Patrolcats
Here is a picture of the retainer;
A new retainer part (if it is broken) may be ordered here at the RepairClinic;
Electrolux Dishwasher Retainer 154622601
Use & Care Guide
http://manuals.electroluxusa.com/prodinfo_pdf/Kinston/154671101en.pdf
Service Data Sheet
http://manuals.electroluxusa.com/prodinfo_pdf/Kinston/154676601.pdf
May 15, 2011 | Electrolux 24 in. EDW5500DSS Stainless...
Ewdw6505gso electrolux. error 1. have turned off
the water will have leaked into the drip pan underneath, which is installed to protect your floors. Unfortunately, only way to get at it is to pull out dishwasher and remove 3 phillips screws that hold it on. In order to repair leaks, Electrolux came out with a "leak kit", which is part number 154769101. Comes with all parts that they had leak issues with
Mar 14, 2010 | Electrolux EWDW6505GS Fully Integrated...
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Electrolux 6505GSO dishwasher. Says ERROR 01 onled panel and will not function. What is this code and how can I make the the thing work?
Dec 31, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
416 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
