Question about Refrigerators
Wheelshot, We have a Sub-Zero 532. A couple of days ago, we discovered that the refrigerator side was only reading 60 degrees. I deiced the condenser coil behind the back panel, checked the compressor and fan for the ref side and they are both running. I also tested the 'cold control' and it would turn on and off. However, the temperature will still only get down to around 50 degrees. Could it need a recharge? What kind of freon does this model need?
  • geraldbetty Jul 14, 2010
    I appreciate the response, but would like to have WHEELSHOT respond also as he seems to have a good understanding about Sub-Zeros. Also, we do not have an owners manual. Can you get us one or tell us where online we can look at one? Thanks, Gerald
  • 2,335 Answers
The Sub-Zero 532 model uses two different refrigerants (R12 or R-134a), in four different quantities, depending on the serial number of your unit.
Wheelshot,
Please find the relevant technical data sheet available for download here.
I hope that helps.
Posted on Jul 14, 2010
    President:
  • 1,561 Answers
There is 100% assurance that the unit is low on freon since all the necessary diagnoses parts are already check and they function well as you said, in this case, you will need to add freon to the compressor on your refrigerator.
As for the kind of freon used, this can only be determine by the manual of the device because i can not give any specification as regards this, but would advice you check the user manual for the kind of freon to be used.
Take care.
Where do I get replacement bulbs for model # 532 side by side refrigerator?
Where do you live? I know a place in Massachussetts that I deal with that carries replacement parts, also one in Connecticut. CLARKE CUSTOMER CARE
Services Sub-Zero and Wolf products
393 FORTUNE BLVD,
MILFORD, MA 01757
Phone: (877) 925-2753
Fax: (508) 458-2274
DONNELLY APPLIANCE SERVICE
1478 BARNUM AVE,
STRATFORD, CT 06614
Phone: (203) 378-6186
Fax: (203) 375-9465
Dec 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
Sub-zero refrigerator not getting cold - model 532
make sure that the compressor filter is clean -- if it hasn't been cleaned recently, can prevent proper operation.
Jun 06, 2010 | Refrigerators
Sub Zero 532 freezes up behind inside back panel on fridge side only. When this happens inside temp goes up to 50 degrees. Removing back panel and rmelting ice only stops the problem for about 8 days. Any...
You have a defrost problem. You need to have the defrost thermostat and heater checked. Once you defrost it, it will take a week to frost up again.
Sep 22, 2009 | Refrigerators
532 sub zero evaporation tray is filling up with a
This is only normal in an environment of high humidity. My question is the condenser fan blowing over the condensate pan and is the air hot enough to evaporate the water that is in the pan? Has covers been removed on the rear of the refrigerator that may cause a different flow of air. Are all covers in there correct place and not missing panels that could change the flow of air over the pan? Let me know, Thanks, Sea Breeze
Aug 26, 2009 | Refrigerators
Power requirement sub zero 532
115 volts on a 15 amp circuit
May 19, 2009 | Sub-Zero 632 / S
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Sub-zero 532 problem
you have a Freon Leak @ the Evaporator.. Ice ball on back wall.. left side....
Apr 15, 2008 | Sub-Zero 632 / S
Refrigerators Logo
385 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
