Question about Rheem Water Heaters
I HAVE A RHEEM WARRIOR CLASS MODEL NUMBER 71V30D, IM NOT SURE IF ITS THE HEATING ELEMENT OR IF THE WHOLE HWH NEEDS TO BE REPLACED.. CAN ANYONE HELP..I HAVE PICS OF WHAT THE PROBLEM IS
  • Rheem Master
  • 43,501 Answers
Here is a tip that will help you troubleshoot that...
Also check out the other tips at the bottom of this one...
Electric Water Heater not Working
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
heatman101
Posted on Jul 16, 2010
How do I replace the heating elements in my Rheem water heater
Replace heating elements can be found at amazon, click here and take a look: Amazon com rheem heating element . I hope this was helpful... cheers
Jan 31, 2013 | Rheem 82V40-2 Fury Electric Residential...
Heating element 887013 replace
Question posted under Rheem water heaters
Rheem parts guide does not show that part number with either flanged or screw-in type.
If this is ordinary tank-type electric water heater, copy following link to see step-by-step.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Otherwise, add a comment or re-post question and include type, brand and model of water heater as shown on product label.
For example Atwood, or Under-counter, solar-assisted, tankless etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 01, 2012 | Rheem Water Heaters
I have a Rheem warrior glass water heater model number 71-30 s in my mobile home. Recently had frozen water pipes and had to take the entire water pipe from the water heater to the main water box off to...
Before I spent the money on a new heater I would check reset to make sure it did not trip. I would also check element and make sure you are getting flow thru outlet and that it did not plug up with rust and mineral .
Depending on the water quality where you live I would expect to get at least ten years use out of a electric heater. Thank you.
Feb 10, 2011 | Rheem Water Heaters
I am only receiving half of the normal amount of hot water.
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Rheem fury series manuals and models
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
C) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
This will restore water heater to full 99% efficiency.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you want to test thermostats and all parts before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
geno_3245_185.jpgRheem 4500 watt element
Dec 14, 2010 | Rheem Water Heaters
Rheem hot water heater
Check the relief valve,drain and element's,water lines to make sure that they are not the source of the leak. If the tank is leaking you may be able to fix it for now.
The tank depending on condition of the tank if it is pretty sound. Clean up the area of the hole with sand paper. Go to any hardware store and get a JB Weld two part kit. JB Weld will fix almost anything . You can go to www.jbweldit.com for more information about this product. I wish you well and hope this will fix it for you.
Jun 26, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Need to relight Rheem hwh. Have not seen unit, but believe it is electric.
electric heaters dont need to be light because they dont use gas, the power is off to the heater or the thermastat is bad or the heating element is bad. call the manufacture and get free customer service and support over the phone.
Apr 27, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
I have a Rheem Warrior Class Model 72-52-2 240/208 wattage, manufature date 9-2005 in a trailer house. The breaker keeps tripping. When I reset the breaker, it will heat for a minute and then trip again....
Yes it is most likely shorted out to test remove the wires after you have disconneted the breaker turn off the water and drain water then remove it and replace it.
Sep 30, 2009 | Water Heaters
Water Heaters Logo
246 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Steve Allison
Steve Allison
Sean Lavelle
Sean Lavelle
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
