Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
On a GE side by side where is the water reservoir
On a GE side by side where is the water reservoir ? The ice maker works fine but the water will not dispense. The owners manual says the reservoir may have frozen. Thank you.
I had the same problem. The line is frozen. GE will not admit there is a problem. I read a suggestion on line & followed up on it. I placed styro foam insulation on door inside the freezer compartment & no more frozen line & water flows freely.
Posted on Jul 14, 2010
GE bottom freezer ice maker not working
Remember there are two sides to a dual water control valve, the water to dispenser side and the side that feeds the ice maker. Replace the WR57X10094 Dual Water Control Valve and I think you will be good to go on ice, Thanks Sea Breeze
Jul 02, 2012 | Refrigerators
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker not working Water works fine in the door. (GE Profile side by side)
heatman101
gfs4
May 29, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Ice Dispenser
If you access the ice container and remove any partially melted ice - maybe the ice maker will work. We had a similar problem. We opened the ice reservoir and discovered ice cubes that had partially melted together. Once we removed those, the ice maker and water dispenser returned to normal. Now we check every so often.
Apr 04, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
477 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
