Question about Asko 24 in. 1805 Built-in Dishwasher
Start switch is gone and strip across top of door needs replaced
  • Asko Master
  • 2,605 Answers
Hello, Welcome to FixYa.
The part`s you`re looking for, the power switch/on-off switch is Asko original part number 80-575-47. Check "repairclinic.com" part number 763255, retails for approx. $20.
The overlay/decor insert across the top of the control panel is Asko part # 80-708-88 (- 0 for white or -33 depending on the color ). Check "repairclinic.com" part number 764259, retail for approx. $80.
Hope that answer`s your question. Let me know if I can assist you further.
Thank you for choosing FixYa today. Please take a moment to rate the answer I provided for you and a testimony if you fell it`s warranted.
Good luck.
macmarkus :)
Posted on Jul 14, 2010
  • Lisa Ensley Apr 15, 2012
    What about the part the the overlay goes on?If the plastic pieces are broken the overlay will not help.
How do I remove and install driver window weather strip on 1985 Chevrolet el camino?
The best way is remove the door panel and take out the glass. Part of the track is bolted in and some of it just presses into the channel. Any of the seals across the top of the door, like if the window is down and your arm is resting on them. These just pry off and push back on.
Sep 22, 2014 | Cars & Trucks
Tip
Whirlpool Dryer Various Test Procedures - Part 3
TEST #5 Moisture Sensor
NOTE: This test is started with the machine completely assembled.This test is performed when an automatic cycle
stops too soon, or runs much longer than expected. NOTE: Dryer will shut down automatically after 2-1/2 hours.
The following items are part of this system: Harness/connection, Metal sensor strips, Machine control electronics
1. Activate the diagnostic test mode and advance past saved fault codes.
2. Open the dryer door. If a continuous beep tone is heard and an alphanumeric number is displayed on the console as soon as the door is opened, a short circuit exists in the moisture sensor system. If this doesn’t happen, go to step 3. Otherwise, go to step 4. NOTE: Over drying may be caused by a short circuit in the sensor system.
3. Locate the two metal sensor strips on the inside of the dryer. Bridge these strips with a wet cloth or finger.
If a continuous beep tone is heard and a software revision number is displayed on the console, the sensor passes the test. Go to step 8. If not, continue with step 4.
4. Access the moisture sensor wires: Remove the lint screen. Remove the two wires holding the lint screen to the top. Remove the four screws from bottom of the duct in rear. Remove the duct from the dryer to access
the moisture sensor.Disconnect the sensor connector.
5. Access the machine control electronics. Remove the connector P13 from the circuit board. Check the main
harness connections between the sensor connector and machine control for a short or open circuit. Replace the main harness if necessary. If the harness is okay, continue with step 6.
6. Measure the resistance across the outermost contacts of the sensor connector that includes the two MOVs. Sensor Harness with MOVs (Metal Oxide Varistors) Sensor Connector Sensor Blower Housing Disconnect sensor connector. If a small resistance is measured, check for debris across moisture strips inside of the drum; clean if debris is present. If debris is not present, replace sensor harness with MOVs. Otherwise go to step 7.
7. Measure the resistance across each of the outermost contacts and the center terminal (ground connection).
If a resistance less than infinity is measured, replace the sensor harness with MOVs.
8. If moisture sensor diagnostic test passes, check the thermistor: Perform TEST #4a. If the problem persists after replacing the moisture sensor, harness with MOVs and thermistor, replace the machine control electronics.
TEST #6 Buttons and Indicators
This test is performed when any of the following situations occurs during the Console Buttons and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard
Some buttons do not light indicators None of the indicators light up:
1. See Diagnostic Guide/Before Servicing.
2. Perform TEST #1 to verify supply connections.
3. Perform TEST #2.
4. Visually check that the P5 connector is inserted all the way into the machine control electronics.
5. Visually check the user interface assembly connections.
6. If both visual checks pass, replace the user interface assembly.
7. Plug in dryer or reconnect power.
8. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
9. If indicators still do not light, the machine control electronics has failed: Unplug dryer or disconnect power.
Replace the machine control electronics. Plug in dryer or reconnect power. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
No beep sound is heard:
1. Visually check that the P5 connector is inserted all the way into the machine control electronics. If visual check passes, replace the user interface assembly.
2. Plug in dryer or reconnect power.
3. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
4. If replacing the user interface assembly failed: Unplug dryer or disconnect power. Replace the machine control electronics. Plug in dryer or reconnect power. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
Some buttons do not light indicators:
1. Visually check the user interface assembly connections. If visual check passes, replace the user interface assembly.
3. Perform the Console Buttons and Indicators Diagnostics test to verify repair.
TEST #7 Door Switch
Activate the diagnostic test mode and perform the Door Switch Diagnostic test.
Functionality is verified with a beep each time the door is closed and opened, and a number and letter appears in the display (i.e., 0E, 09). If any of the above conditions are not met: Unplug dryer or disconnect power.
Check that the wires between the door switch and machine control electronics are connected. If the connections are OK, replace the door switch assembly and retest. If the door switch assembly has been replaced and dryer still does not start, replace the machine control electronics.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Broken freezer door handle
The O in you model should stand for Overlay panel and that would mean the handles were purchased separately to match the rest of the cabinet work. The handle is also mounted to the wood panel. To remove the panel pull the freezer drawer out and look at the metal trim across the top. You should see a strip across the middle of it. That strip is held in with magnets. Put a piece of duct tape on it and it should pull out. If there have been any spills it can cause the strip to stick and you may need a putty knife to help pry it free. Once the strip is out you will see the screws holding the top trim in place. Remove the trim and the panel will slide out the top of the drawer and the screws holding the broken handle will be accessible.
Sep 28, 2013 | Sub-Zero 650 / O Bottom Freezer...
Replace starter switch
Putty knife to release the top then lift the top off there. I ain't never seen a start switch break yet. Your fuse is probably gone or door switch broken. Start switch nawsir. Rare.
Small disk on rear upper right hand corner is the fuse. If open the dryer will not operate.
Jul 10, 2012 | Frigidaire FEQ1442ES Electric Dryer
I'm getting an "FL" message.
FL - Failed to Lock
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
You can get it at a local appliance parts dealer near you or online and to replace it you will need to open the door, remove the screws that run though the hinges into the cabinet and the ones straight across on other side, pop the top of the front panel loose and take off, remove the screw at the top of each side and raise the top panel and swap it out; check this DIAGRAM PARTS LOCATION
Hope this helps.
Aug 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
Every time the top frig door is closed the bottom freezer door opens sometimes only 10 or 15mm so that the alarm does not detonate. The reverse also happens, ie top door opens when the bottom door is...
There is an air duct that connects the fridge to the freezer. When the opposite door is closed air is trapped and forced out the other door pushing it open.
The door seals contain a magnetic strip that hold the door to the fridge, these magnetic strips have lost their strength, to test this use a shhet of paper. Open the door, place the sheet of paper across where the door closes, shut the door, then slide the paper out. If the paper comes out without any resistance then the door seal needs to be replaced.
Mar 31, 2011 | Fisher and Paykel E522BRXFD Stainless...
The opening door handel broke off.
This is a generic response to your comment
Look at the inside of the door, you will probably find a plastic strip which can be pried out. Underneath the strip, you will find the screws that hold the door together. The screws may be "torx" head.
Take pics of your door with your cell phone as you work and remember, most doors are spring loaded. Watgch your fingers.
Once the door is split open, replacing the handle should be a simple matter.
I hope this helps you
a
Sep 22, 2009 | Jenn-Air JMV8208A Microwave Oven
Maytag neptune washer MAH-1 start button turns off, does not spin
Hi!
Is it pumping water? If not then pump is bad.
Is the door locking? If the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
Check for continuity across the Door Lock, Spin Enable Switch when the switch actuator button is pressed in. If there is no continuity across the Door Lock, Spin Enable Switch, replace the Door Lock Switch Assembly.(Check for 120 vac across the Door Lock Wax Motor)
Please rate this solution and ask for further clarifications if needed.
Thanks
Rylee
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
GBC Shredmaster 5260X - door is closed by light indicates otherwise
This shredder has a magnet built into the door. If you open the door you'll see a metal strip on top right side of shredder. Either the magnet is not getting close enough to activate the reed switch or the hinges have came loose allowing a door sag condition. Also, if the shredder isnt that old, just contact GBC for some warranty work at 800-790-7787
Oct 03, 2008 | Office Equipment & Supplies
Hardware error message 0502 shows up on the display. What does this mean?
Cause
The encoder strip may have gone out of range of the sensor, or it might be dirty.
Resolution
You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.
Check the encoder strip
  1. Switch off the printer using the power button.
  2. Disconnect the power cable from the back of the Lexmark X5100/X6100 Series.
  3. Leave the power cable disconnected for 30 seconds.
  4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
  5. Take out both cartridges.
  6. Place an index finger on the encoder strip on either side of the cartridge carrier.
    The red arrow points to the encoder strip. Click here
  7. for an enlarged view.
  8. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
  9. Lightly press the strip first to the rear and then forward, if necessary.
  10. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
    Click here for an enlarged view. The contacts on the back of the cartridge carrier are the ones to clean. Use a dry tissue.
  11. Reconnect the power cable and switch the printer on again.
  12. Perform the hardware test first without cartridges and then with both cartridges. Click on the applicable document below. How to Perform the Hardware Test on the Lexmark X5150
    How to Perform the Hardware Test on the Lexmark X6150/X6170
  13. Make a standalone copy.
  14. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Sep 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Asko 24 in. 1805 Built-in Dishwasher Logo
289 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
